![]() | Home > Technical (L322) > Radiator/Cooler in Drivers Side Wheel Well |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
oil cooler me thinks ... - .- -.
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 228 ![]() ![]() ![]() |
It is an auxiliary radiator for the cooling system, think a new one is about £270 from Land Rover in the UK. |
not oil cooler then |
No although I am sure I have seen diagrams saying it is an oil cooler.
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
Due to package constraints an auxiliary radiator is required to maintain acceptable coolant temperatures under arduous driving conditions such as high-load and high ambient temperatures. This radiator is located in the in the RH wheel arch area, with cooling airflow supplied by a dedicated aperture in the front bumper. The auxiliary radiator is connected in parallel with the main radiator, with the coolant flow being controlled by the main engine thermostat. 2007 L322 3.6 TDV8 Stornoway |
beep-beep Member Since: 02 May 2018 Location: Dublin Posts: 13 ![]() ![]() ![]() |
Cheers gents! Was pretty sure it was the AUX heater but wanted to double check! |
