Home > Technical (L322) > Advice please, lower tailgate switch
Stormin
2003 Range Rover HSE Td6 Epsom Green
I have an intermittent problem where the switch on the lower tailgate doesn't unlatch the tailgate, however if I press the tailgate button on the fob it opens every time.
I'm suspecting the actual switch is faulty and Dan has kindly quoted for a new one but at £56 I didn't want to part with my cash unless I'm certain. Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #528517 19th Sep 2019 9:31am
GGDR
remove the switch and check it with a multimeter?
. Cheers, Greg
Post #528527 19th Sep 2019 12:42pm
rjff
+1 as per GGDR
I've not had the switch out, but If the lower gate doesn't operate on the pushing of the "rubber" button on the tail it may be that the cover does not properly push down on the switch. Perhaps check that it will operate when the cover "rubber" is off and you have access to the switch directly. A bit like the wearing down on a remote that sometimes happens, the little button on the inside of the cover reducing in length. Not a good explanation, but you shoud work it out. Confused Cheers
Richard
Gap IIDBT
Post #528546 19th Sep 2019 3:50pm
Stormin
Thanks for your replies, I have acquired a multimeter but don't know what to set it at. Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Previous cars
1973 Mini 1000
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1996 BMW 730
2003 Honda CRV
Post #528703 21st Sep 2019 10:22am
rjff
Have the meter on resistance, (may be an OHM sign or a buzzer) and check its reading when you touch the probes together.
To trest the switch on its own, remove it from the lower tailgate. Remove the connector and if there are two wires into the switch connect the meter across the switch terminlas. Operate the switch by hand and if you get the zero readgng or buzzer it should be OK. Reconnect the switch and operate it with the ignition on to see if it works the tailgate latches. If it does't, then the problem is a little deeper. Cheers
Richard
Gap IIDBT
Post #528763 22nd Sep 2019 12:15pm
