Home > Technical (L405) > "Service Required"
dolph34
My 2007 VSE 3.6 had its oil changed ever 5k kilometres and the oil was like new every time it was changed. My 2011 and 2015 have had the oil sucked out so you can't see as it sucked into a 200lt drum. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #528959 24th Sep 2019 6:47pm
supershuttle
Baltic Blue wrote:
Geoff,
I strongly recommend that next time you go out and get the car up to normal working temperature, when you stop the engine, wait 20 minutes then check the oil level.
It is so easy to accidentally put in too much oil when changing it.
If you get an overfilled message, then get him to suck out 0.5 l before it does any damage.
If it reads anywhere between 3/4 and full , then you know he did a good job.
Mike.
All good Thumbs Up Geoff
Post #529106 25th Sep 2019 7:45pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I change mine every 6k miles without fail. Shel helix ultra and a new filter, oil is always black. I have a special machine that sucks the oil out of the Service tube.
Was told by the dealer this is the best way, as the days of old are behind us. The sump on the L405 is not designed to be drained from below anymore as the plug is higher than the lowest point.
I was told by the master tech that a specially designed gully/channel in the sump is designed to bring all the oil to meet the bottom of the suction tube thus allowing all the crap that settles to be sucked out. Makes interim services easy. And this is the process LR designed to free up ramp space for other repair work. And that's why the dealers use vaccum pumps to take your old oil out. No ramp required
Post #529213 26th Sep 2019 8:37pm
revoke
This letter is definitely worth a read as it expands on the meaning of the phrase "architecture and hardware" contained in JLRP00100:
https://www.discosportforums.co.uk/download/file.php?id=9522
Post #529280 27th Sep 2019 12:20pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Vogue wrote:
Don’t ignore the service required notification - your oil is contaminated, probably due to short journeys
Just to be clear, are there two service indicators, one specifically for oil, and the other for general servicing?
I checked my oil today and it appears to have gone up, not down Sad
I also get a service message with a "spanner" - what does that mean?
What's the warning specific to oil dilution getting too high?
Thanks
Post #696661 22nd Jul 2024 4:46pm
It looks like there’s a surplus of diesel on the oil due to failed regens.
As far as I know, this is the only item that determines t when the service is due, but I could be mistaken. Got - 2017 SDV8 Autobiography in Loire Blue
Post #696667 22nd Jul 2024 6:17pm
supershuttle
I used the back door rather than my idtool only recently (may/june) I’ll use the tool this time now I’ve found it again. I’ll also check the oil level. Geoff
Post #697984 13th Aug 2024 1:16pm
supershuttle
Duplicate deleted. Geoff
Post #697992 13th Aug 2024 2:03pm
