Home > Off Topic > Topping up pressure in Worcester Bosch Greenstair 30i
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Know its not even car related guys, but you lot are pretty helpful..... Bow down
Below is the pipework under our Worcester Bosch Greenstar 30i combi boiler. Just bled the radiators and now 0 pressure. Gauge reading 0 as expected. (photos are upside down, but cant work out how to rotate 180 degrees)
I assumed opening the 2 valves on the flexi pipe would fill the system, and i could shut it off at 1.5 bar (where it should be), but i opened both valves (1 was open already) and expected to hear flowing water from the mains, but nothing?
Any ideas??
Post #527543 10th Sep 2019 11:48am
mrblonde
All sorted, the valve that was stuck 'on' (the slot going same way as flow of water), ws actually stuck off
So all sorted now
Post #527554 10th Sep 2019 12:52pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
I can't see from that pic but were both valves screw slut facing vertically? Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #527555 10th Sep 2019 12:53pm
ianmacd
So all sorted now
Good. Current: RR L322 2010
Post #527558 10th Sep 2019 1:04pm
