Home > Wheels & Tyres > largest profile tyre on a 22" wheel
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As above, recently switched my old 22" alloys that had 35 profiles on, for a set of L405 22" alloys with a 40 profile tyre on and the difference is very noticeable, sooooooooooooooo
was wondering if you could use a 45 profile on a 22" wheel? Embarassed
Post #527442 9th Sep 2019 11:11am
JJbing
You can't, tried and they rub the arches. 40 is the max, unless you make other adjustments
Post #528578 19th Sep 2019 11:10pm
Vogue
You can fit 285/40/22 which gives a slightly deeper wall than 275/40/22 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #528590 20th Sep 2019 5:46am
Not sure you can on a 322 Vogue... yes for sure you can on a 405 but I think the 275 was the limit of the rear wheel arches... Happy to be told different! Very Happy Thumbs Up
Post #528608 20th Sep 2019 10:25am
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I’ve got 285/40/22 on my L322 with Discovery 5 wheels and have no issues
Post #528749 22nd Sep 2019 6:08am
DBB
United States
285/40R22 on oem L405 wheels will clear the rear arches
Post #528996 24th Sep 2019 10:45pm
datafoo
United States 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
285 clears but its not the tire you need to be conscious of, its the wheel offset.
Make this a 22x10 wheel in pretty much any tire size and you'll rub. A 22x9.5 with like 49 offset (think L405 wheels or redbournes) clear no problem. Might even be able to stiff a 305 in there with the right offset wheel.
Inside clearance is a problem too. I have 20x9.5 L320 rims on my MY06 with 285/50/20s and they almost rub the shock tower inside. 2012 L322 SC Ipanema Sand
2012 L322 Autobiography Santorini Black
2006 L322 HSE LUX Zambezi Silver
Newton's 42nd law: If you run around a tree fast enough, you will inbox yourself. Quotes are silly.
Post #529004 25th Sep 2019 4:20am
DBB
United States
The OP was referring the L405 wheels which are 22x9.5 et49. For that wheel width and offset, the 285 width is the widest tire that will clear the metal flanges in the rear arches during heavy compression or when on bumpstops.
I have tested this setup with 285/40R22 Pirelli Scorpion Verde PCNS and clears the front struts, rear arches and rear fuel filler bulge without any modification (even on bumpstops by using the IID tool)
I have tested the 305/40R22 Pirelli Scorpion Asimmetrico. The tire looked too "bulged" on the 9.5" rim and does not clear the rear arch flanges when tested on bumpstops. The 305/40R22 is a better fit on the 22x10 ET42.5 SVR wheel (current setup)
285/40R22 is sure thing on the OEM L405 wheel. I would be interested in seeing a 285/45R22. This seems close to the overall size of the 275/55R20 a lot of people use for their offload set.
Post #529124 26th Sep 2019 3:58am
datafoo
I do realize this. I read the thread.
Do you realize that L405+L494 wheels come in 22x10 size as well?
Your tolerances are appx 11" wide and 31.5" diameter. Using the right offset of course. 2012 L322 SC Ipanema Sand
Post #529166 26th Sep 2019 2:55pm
DBB
United States
From my knowledge,the L405 22” wheels are 22x9.5 ET49. The only L494 wheels that are 10” wide are the 22” SVR wheels with an offset of 42.5.
If there are other OEM 22x10 wheels, I would be interested in seeing which models. Always nice to change wheels out every now and then.
Post #529169 26th Sep 2019 3:25pm
elhack
DBB, are you running the 22x10 SVR wheel on a L322? I've been looking at them but the offset is concerning to me.
Post #555844 29th May 2020 10:39pm
DBB
United States
Elhack, yes, I am currently running the OEM 22x10 SVR wheel with a 305/40R22 Pirelli Scorpion Asimmetrico tire. This has been the most “flush” with fender setup I have tried.
I have a second set OEM SVR 22” wheels and 285/40R22 tires, if you are interested DM me.
Post #555854 30th May 2020 4:49am
elhack
Do you have any pics of this setup? I would DM you but I am apparently short on post count being new to the forum.
Post #555855 30th May 2020 4:52am
elhack
Sorry for the derail, I'm currently running 20x9.5 Stormer OEM wheels with 305/50R20 and really think I'm pushing the limits on offset/height and ran across this post.
Post #555856 30th May 2020 4:54am
DBB
United States
The setup I am running clears the front struts perfectly (less than a finger gap but doesn’t touch) and sits flush with the fenders. Probably the most aggressive tire size that can be used without sticking out past the fenders.
Post #555857 30th May 2020 5:03am
