![]() | Home > Wheels & Tyres > largest profile tyre on a 22" wheel |
JJbing Member Since: 15 Oct 2014 Location: York Posts: 5 ![]() ![]() |
You can't, tried and they rub the arches. 40 is the max, unless you make other adjustments |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
You can fit 285/40/22 which gives a slightly deeper wall than 275/40/22 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Not sure you can on a 322 Vogue... yes for sure you can on a 405 but I think the 275 was the limit of the rear wheel arches... Happy to be told different! |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I’ve got 285/40/22 on my L322 with Discovery 5 wheels and have no issues |
DBB Member Since: 18 Mar 2016 Location: United States Posts: 42 ![]() ![]() |
285/40R22 on oem L405 wheels will clear the rear arches |
datafoo Member Since: 25 Mar 2019 Location: Los Angeles Posts: 17 ![]() ![]() ![]() |
285 clears but its not the tire you need to be conscious of, its the wheel offset.
The OP was referring the L405 wheels which are 22x9.5 et49. For that wheel width and offset, the 285 width is the widest tire that will clear the metal flanges in the rear arches during heavy compression or when on bumpstops.
I do realize this. I read the thread.
From my knowledge,the L405 22” wheels are 22x9.5 ET49. The only L494 wheels that are 10” wide are the 22” SVR wheels with an offset of 42.5.
elhack Member Since: 29 May 2020 Location: USA Posts: 8 ![]() |
DBB, are you running the 22x10 SVR wheel on a L322? I've been looking at them but the offset is concerning to me. |
Elhack, yes, I am currently running the OEM 22x10 SVR wheel with a 305/40R22 Pirelli Scorpion Asimmetrico tire. This has been the most “flush” with fender setup I have tried.
Do you have any pics of this setup? I would DM you but I am apparently short on post count being new to the forum. |
Sorry for the derail, I'm currently running 20x9.5 Stormer OEM wheels with 305/50R20 and really think I'm pushing the limits on offset/height and ran across this post. |
The setup I am running clears the front struts perfectly (less than a finger gap but doesn’t touch) and sits flush with the fenders. Probably the most aggressive tire size that can be used without sticking out past the fenders. |
