![]() | Home > Technical (L405) > Keyless entry |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1039 ![]() ![]() ![]() |
On my 65 plate car you lock by tapping either the driver’s or front passenger door handle where there is a small indentation. Works every time on my car. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
All 4 handles can lock mine |
notty Member Since: 05 Jun 2017 Location: NE Hants Posts: 35 ![]() ![]() ![]() |
Unnecessary quote removed
To be honest, I’ve never tried to lock using the back doors....😀 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3858 ![]() ![]() ![]() |
Mines a bit temperamental, if the key is close then locking doesn’t work because the car thinks the key may be inside. The solution for me is just to move the key further away (or if in pocket just turn away putting body in the way) then locking works from all 4 doors. Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
its a security risk, disable it and there will be less chance of it being nicked... ... - .- -.
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Our disco sport is disabled, sometimes it’s a bit of a faff but got used to it now. Whilst the Range Rover was in the dealer for a job to be done they lent us a disco 5 for a few days. I told them I was disabling the system, to which they said it couldn’t be disabled. 30 secs later, they couldn’t get in using keyless way. I did return it to keyless when I returned the car. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Disabled mine as soon as i bought it... Much the same as using our D4 now... |
My tin only reduces the range so I tried to disable - failed. Maybe I did something wrong, three presses of the light button on the fob then a press of the unlock. Tried at a couple of times and failed |
Sorted now only unlocks with key |
it gives you peace of mind doesnt it geoff... ... - .- -.
It means I can go back to my old ways of just slinging the keys on my table without having to put them in my tin. None of my previous Range Rovers had keyless locking so I won’t miss it. BTW I had to “cycle” the process to get it to work, first I enabled keyless locking (although it already had it) and then disabled |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 883 ![]() ![]() ![]() |
I’ve tried several times & failed to disable mine using the process exactly per the Powerful video - it’s a 2014 model.
Two things to watch for
