Home > Technical (L405) > Keyless entry
notty
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Loire Blue
Keyless entry
I’m unsure whether this is a fault or a configuration, but my (new!) 2015 L405’s keyless entry seems to be acting up.
When locked, keyless unlock works on every door handle.
However, not a single door handle is able to lock the car. Neutral
Am I missing a configuration somewhere, or is it a trip to the dealers?
Paul L405SC just arrived... still working everything out!
Post #527416 8th Sep 2019 9:45pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
On my 65 plate car you lock by tapping either the driver’s or front passenger door handle where there is a small indentation. Works every time on my car.
Post #527480 9th Sep 2019 6:12pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
All 4 handles can lock mine Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #527490 9th Sep 2019 8:23pm
notty
Unnecessary quote removed
I’m thinking it’s a fault somewhere as opposed to my missing an option setting somewhere. 😬
Guess I’ll be calling the dealer tomorrow.
P L405SC just arrived... still working everything out!
Post #527492 9th Sep 2019 8:30pm
Andy S
To be honest, I’ve never tried to lock using the back doors....😀
Post #527493 9th Sep 2019 8:35pm
supershuttle
Mines a bit temperamental, if the key is close then locking doesn’t work because the car thinks the key may be inside. The solution for me is just to move the key further away (or if in pocket just turn away putting body in the way) then locking works from all 4 doors. Geoff
Post #527506 9th Sep 2019 9:55pm
its a security risk, disable it and there will be less chance of it being nicked... ... - .- -.
Post #527512 10th Sep 2019 5:20am
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Our disco sport is disabled, sometimes it’s a bit of a faff but got used to it now. Whilst the Range Rover was in the dealer for a job to be done they lent us a disco 5 for a few days. I told them I was disabling the system, to which they said it couldn’t be disabled. 30 secs later, they couldn’t get in using keyless way. I did return it to keyless when I returned the car.
Post #527628 10th Sep 2019 10:10pm
Disabled mine as soon as i bought it... Much the same as using our D4 now... Thumbs Up
Post #527630 10th Sep 2019 10:25pm
supershuttle
My tin only reduces the range so I tried to disable - failed. Maybe I did something wrong, three presses of the light button on the fob then a press of the unlock. Tried at a couple of times and failed Big Cry but I did manage to switch the lights on. Geoff
Post #527644 11th Sep 2019 7:46am
supershuttle
Sorted now only unlocks with key Thumbs Up Geoff
Post #527679 11th Sep 2019 12:05pm
it gives you peace of mind doesnt it geoff... ... - .- -.
Post #527680 11th Sep 2019 12:10pm
supershuttle
It means I can go back to my old ways of just slinging the keys on my table without having to put them in my tin. None of my previous Range Rovers had keyless locking so I won’t miss it. BTW I had to “cycle” the process to get it to work, first I enabled keyless locking (although it already had it) and then disabled Thumbs Up Geoff
Post #527682 11th Sep 2019 12:19pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I’ve tried several times & failed to disable mine using the process exactly per the Powerful video - it’s a 2014 model.
Is there a trick I’m missing perhaps? Neutral
Post #527711 11th Sep 2019 4:33pm
supershuttle
Two things to watch for
1 keep the drivers door open ( I didn’t initially because it was raining)
2 I performed the routine to enable first then disabled (both as per the Powerful video) Geoff
Post #527715 11th Sep 2019 4:58pm
