Home > Technical (L322) > Range Rover l322 Td6 gearbox issue
Stenstace
Hi all, i have a l322 td6, my issue is i can start the car and reverse it up the driveway, put it into drive and its runs through the gears all fine for about half a mile, it then goes into trans failsafe mode and only seams to use 4th and 5th gear, it still drives for as far as you want but just using 4th and 5th and the trans fail safe message on screen, it also still engages reverse, i checked the transmission fluid level today at 40°c and i was able to add approx 600ml, i took the car out and it behaved exactly the same, iv checked it on Delphi diagnostics and it brings up code 36 & 37 and states " transmission constantly slipping"
Any ideas would be greatfuly recieved.
Thanks in advance
Steve.
Post #527335 7th Sep 2019 6:35pm
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
have you tried to change oil and filter?
Post #528426 18th Sep 2019 11:08am
Rosco
Contact Stuart at Birch Motors, Liverpool, they will sort it, needs a refurb/TC possibly Thumbs Up
Post #528429 18th Sep 2019 11:59am
