Home > Technical (L322) > 2006 Supercharged gearbox question
ruprechtmonkey
Hi all, I've had my 2006 Supercharged L322 for coming up to year now and it's always had an issue with the gearbox. When pulling away from standstill at full throttle the gearbox slips in second gear and goes straight to third. Driving normally it doesn't slip at all and it also doesn't slip when kicking down from higher gears into second. No other gears slip. I had the gearbox serviced a few months back and it hasn't made any difference.
Has anyone got any ideas what could be causing this? I've done a bit of reading and the solenoids appears to be a common issue. Either that or it's knackered and needs a rebuild. Car has done 95,000 miles with full LR and specialist history.
Thanks in advance.
Post #528422 18th Sep 2019 11:41am
