![]() | Home > Maintenance & Mods (L405) > Tracker fuel shut off options |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1436 ![]() ![]() |
Well basically it could end up starving the fuel delivery system down the line. So the high pressure fuel pumps for the injector rails may run dry /empty /starved and become unlubricated from no fuel... Potentially leading to damage of same.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
And what will your thief do by the side of the road with a dead car (and a box of matches) |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 363 ![]() ![]() |
I'd have it triggering a dual pole relay fitted to the start stop button, one pole activates stop and the other to disconnect the start side to prevent a restart. Current
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
Its all well and good until the vehicle gets shut off on a busy junction, in the path of a 38 tonner... |
It's powered by a tracker so you'd already be logged onto the tracking software and be able to see where the car is real time and decide where to stop it.
