Home > Maintenance & Mods (L405) > Tracker fuel shut off options
basil
2014 Range Rover Autobiography 5.0 SC V8 Mariana Black
I have a third party tracker that I will get fitted to my 2014 L405, and it comes with a relay suggesting that you connect it to the fuel pump. However LR technical suggest that this is a bad idea (no idea why I didn't talk to them) - So my question is has anyone done this, how did they do it, or what would you suggest for remote disabling?
Thanks.
Post #526897 2nd Sep 2019 8:59pm
fisha
Well basically it could end up starving the fuel delivery system down the line. So the high pressure fuel pumps for the injector rails may run dry /empty /starved and become unlubricated from no fuel... Potentially leading to damage of same.
I suppose it's a balance of the risk of that versus losing the whole car to theft. V8 or else ...
Post #527737 11th Sep 2019 9:44pm
And what will your thief do by the side of the road with a dead car (and a box of matches) Shocked .
Post #527738 11th Sep 2019 9:48pm
andygts
I'd have it triggering a dual pole relay fitted to the start stop button, one pole activates stop and the other to disconnect the start side to prevent a restart. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #527740 11th Sep 2019 10:14pm
Its all well and good until the vehicle gets shut off on a busy junction, in the path of a 38 tonner... Whistle
Post #527746 11th Sep 2019 11:40pm
andygts
It's powered by a tracker so you'd already be logged onto the tracking software and be able to see where the car is real time and decide where to stop it.
It could be intentional, they wouldn't be nicking cars again Twisted Evil Current
Previous
Post #527964 14th Sep 2019 4:06am
