Home > Technical (L322) > No EAS lights on centre console controls
nosmo
So my battery went flat (FFRR sat waiting for good weather repairs)
The suspension has dropped somewhat.
Now after fully charging the battery the EAS lights on the centre console are not li and the car will not raise to normal heightt.
No dash warnings coming up.
I read I have to reset the EAS
Can I do that with my iCarsoft LR v1.0 or INPA software ?
Thanks in advance 2003 4.4 V8 Vogue
Post #525582 20th Aug 2019 7:46pm
mjdronfield
You could try doing steering fully left, then fully right with the engine running.
Failing that, probably a hard fault and needs diagnostic tool to read and reset.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #525600 20th Aug 2019 8:56pm
mjdronfield
Not sure if you can do it with those tools as I’ve not used them. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #525601 20th Aug 2019 8:57pm
nosmo
That was the question being asked??
If I can use the tools I have?
I will try the left>right trick but I think that only works if you have the dash warning which I dont... 2003 4.4 V8 Vogue
Post #525609 20th Aug 2019 9:08pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
that's odd , everytime ive either disconnected or let the battery go flat ive always had the air suspension inactive warning come up and it has always reset via lock to lock trick , I have used INPA to read codes via the X53 X5 setting Thumbs Up
Post #525624 21st Aug 2019 4:04am
nosmo
Well I disconnected the battery for about 30 mins. After connecting back up I did get the dash error. However the lock to lock trick didnt do anything. Any ideas? 2003 4.4 V8 Vogue
Post #526504 29th Aug 2019 10:27pm
Have you read the fault codes with your iCarSoft or INPA ? .
Post #526523 30th Aug 2019 8:09am
nosmo
Cant get INPA to configure correctly.
The iCarsoft says ECU fault.
Surely its not if its just been left standing a while.
What do I need to try a hard reset? 2003 4.4 V8 Vogue
Post #526760 1st Sep 2019 5:09pm
nosmo
No ideas anyone please? 2003 4.4 V8 Vogue
Post #527742 11th Sep 2019 10:22pm
make sure the battery holds its charge, if youare unsure put a new one on.. ... - .- -.
Post #527752 12th Sep 2019 6:39am
nosmo
Charge battery and reset with iCarSoft. Thanks for the tips Smile 2003 4.4 V8 Vogue
Post #529994 3rd Oct 2019 10:28pm
Walter Skinner
Bulgaria 2019 Range Rover Autobiography 2.0 PHEV Barolo Black
No lights on dash means hard error, they can't be treated with steering left-right, you need a tool to reset them.
Your last post reads like you've got it solved, hooray; but everybody forgot about the fuses: #57 in the gloves departments & big one in the trunk.
Post #530002 4th Oct 2019 4:28am
