![]() | Home > Technical (L322) > No EAS lights on centre console controls |
nosmo Member Since: 05 Nov 2017 Location: Derbyshire Posts: 41 ![]() ![]() |
So my battery went flat (FFRR sat waiting for good weather repairs)
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
You could try doing steering fully left, then fully right with the engine running.
Not sure if you can do it with those tools as I’ve not used them. 2011 Range Rover Vogue SE 4.4 TDV8
That was the question being asked??
Well I disconnected the battery for about 30 mins. After connecting back up I did get the dash error. However the lock to lock trick didnt do anything. Any ideas? 2003 4.4 V8 Vogue |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Have you read the fault codes with your iCarSoft or INPA ? .
Cant get INPA to configure correctly.
No ideas anyone please? 2003 4.4 V8 Vogue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
make sure the battery holds its charge, if youare unsure put a new one on.. ... - .- -.
Charge battery and reset with iCarSoft. Thanks for the tips |
Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 61 ![]() ![]() ![]() |
No lights on dash means hard error, they can't be treated with steering left-right, you need a tool to reset them.
