![]() | Home > General > window left open - locking car? |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
You need to hold the lock button, then the windows and sunroof will close. |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
thank you ![]() |
You can do the same in reverse.
gets even better - thank you ![]() thats what is great about this forum - people helping others - well done |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
I was sorely tempted! ![]() |
well, the solution kindly offered by Mr Fox does not work on my car ![]() so i guess its another 'thing' that needs to be 'switched on' by main stealers my patience is starting to run very short with LR/RR today ![]() |
Have you pushed the button to lock/unlock and then pushed the same button again and held it down for several seconds?
+1 |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Don't you also have to be pointing the key at the drivers door lock? Ash
Please don't take this the wrong way - but this really is covered comprehensively in the manual... |
Japseroony Member Since: 18 Nov 2008 Location: North East Posts: 402 ![]() ![]() ![]() |
I have a possible answer here for you guys.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
if you push all three buttons and shake it at the same time your car changes colour... V8 facelift Range Rover Autobiography 22" wheels.
Really good advice and very helpfull ![]() "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35492 ![]() ![]() |
![]() Y. O. L. O. . |
