Home > Maintenance & Mods (L322) > Viscous coupling pulley retaining tool 303-1241 ? |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I got mine from here (assuming that's what you are after):
15th Aug 2019 6:56pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 688 |
I just used a thin chisel between the bolt heads, but you could probably use a piece of 15mm wide steel. Key thing is at least 3 or 4 hands to hold the pulley "blocker" and the viscous fan tool + hammer.
15th Aug 2019 7:05pm |
leusfx Member Since: 24 Jul 2018 Location: prague Posts: 25 |
In order to remove Cooling Fan the Work Shop manual for TDV8 2006-2010 says that I need Special Tools.
15th Aug 2019 9:32pm |
The Viscous coupling pulley retaining tool 303-1241 is just a device to hold the pulley stationary while you use the fan nut spanner to loosen the big 36mm nut.
15th Aug 2019 10:40pm |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
I always use a "heel bar" , pointed end on the nut and a good whack with a 4lb hammer , keep the bar as vertical as you can and 3/4 the way across the nut (to the right hand side when looking down at it standing in front of the vehicle), will give you a better turning moment of torque, normally shocks them off with no problem , remember its a left hand thread ! |
16th Aug 2019 9:34am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 737 |
16th Aug 2019 1:00pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
and mine
16th Aug 2019 3:35pm |
That's nice collection of tools. Thank you all very much to make it clear!
16th Aug 2019 9:03pm |
i never undid the four bolts RR 2005 4.4 petrol
17th Aug 2019 10:15am |
remove 4 bolts only if you intend to change fluid inside viscous coupling. 2012 TDV8 Black Edition
17th Aug 2019 10:37am |
Eventually, I ordered Part No. LRT146-2PC from powerfuluk.com (Retaining tool and the 36mm Spanner) and it worked like a charm. The tool is also compatible with FFRR TDV8 engine and fits on the pump. Thanks everyone. |
17th Sep 2019 3:11pm |
