Home > In Car Electronics (L405) > Update sat nav maps
Ocean53
United Kingdom 2018 Range Rover Vogue SDV6 Corris Grey
Update sat nav maps
Anyone done this?
Took 9 hours to download onto usb stick!
How long and how do you upload to the car?
Post #524774 14th Aug 2019 1:47pm
should be around 2-3 hours...the best way to do it is to plug the usb in and leave it there until its fully loaded ..you can stop and start as many times as you like and it will resume loading on your next trip.. ... - .- -.
Post #524776 14th Aug 2019 1:56pm
Also, be aware that you will have no sat nav and no music during the update
Post #524777 14th Aug 2019 2:01pm
Ocean53
Thanks. Fingers crossed then.
Post #524794 14th Aug 2019 3:31pm
Ocean53
Do I have to have ignition on or can I just plug it in at night?
Post #524797 14th Aug 2019 3:59pm
the ignition needs to be on so leaving it to upload without overnight wont work...but leaving the ignition on for a long period will flatten the battery.. ... - .- -.
Post #524808 14th Aug 2019 4:25pm
Fifth Horseman
Re: Update sat nav maps
Ocean53 wrote:
Anyone done this?
You must have a fairly slow internet connection then - don't worry, it takes me about 12-15 hours to download map updates to the USB stick.
The good news is I have found with the inControl Touch Pro system it only takes 20-30 minutes to load the new maps from the USB stick. As mentioned the ignition needs to be on and engine running for the duration of the update.
Post #524824 14th Aug 2019 7:12pm
Fifth Horseman
From the owners handbook -
Quote:
The USB drive must not be removed, or the ignition switched off, before the update is complete. Doing so cancels the map update and potentially leaves the system without any available map data.
Also it is strongly recommended to use a USB3.0 device due to the size of the files being transferred - anything else may result in much longer times to load the map updates.
Post #524825 14th Aug 2019 7:20pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Can I do this on a 2014 car.... how? Thanks in advance 👍 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #524837 14th Aug 2019 8:42pm
Fifth Horseman
For a 2015 vehicle the only official option is to buy a USB key with the map and an activation code from here. However the map data is from late 2017.
For the Gen2.1 such as yours, the download process is as Stan describes.
There are unofficial options with more recent mapping but you need to search for them.
Post #524891 15th Aug 2019 8:23am
Gazm007
United Kingdom 2013 Range Rover Autobiography SDV8 Havana
As i found out to my peril driving on s family holiday to France last weekend. trying to explain to the kids why they couldnt watch their DVD did not go down well!!
Post #524954 15th Aug 2019 4:46pm
Ocean53
Thanks for your help Chaps.
Uploaded in 20 minutes.
Post #524978 15th Aug 2019 7:14pm
good job Thumbs Up ... - .- -.
Post #524982 15th Aug 2019 7:28pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Where are these maps downloaded from and are they any better than the original Ladybird book of roads that came with the car. letters not necessarily in the right order
Post #525068 16th Aug 2019 4:10pm
only genuine/official maps are allowed to be linked to on the forum..
https://landrover.navigation.com/en_GB/LandRoverEMEA/GBP ... - .- -.
Post #525076 16th Aug 2019 5:01pm
