![]() | Home > Technical (L322) > Front suspension bottom arm bushes and ball joints - FIXED |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
Most definitely and your front tyres will be getting scrubbed out too. |
Thanks for confirming, I was pretty sure when I looked in there LOL BMW i3 Electric Car
Unfortunately the weather messed up my plans for getting them done this weekend. Will report back as soon as they are done. Here is the E-bay link to where I got them from. https://www.ebay.co.uk/itm/POWERFLEX-FRONT...2749.l2649 |
Thanks for the link and I look forward to the update. BMW i3 Electric Car
Does anyone have a used pair of the TCAs that they want to sell? I could fit my Powerflex bushes to them and then just swap the arms over. Would save the car being off the road for so long and as there are no ball joints on the arms, nothing else to wear. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
They look easy to fit, am I right in thinking no press needed ?
Yes, dead easy to fit, the bush is split with a stainless sleeve that goes through both parts. It will be getting the old ones out that will be the main issue, hence my request for some used arms. Annoyingly, I didn't keep my old ones from a few years back. |
I saw /read somebody 'collapsed' the old one out.
nosmo Member Since: 05 Nov 2017 Location: Derbyshire Posts: 41 ![]() ![]() |
Where did you order from Frexan ? 2003 4.4 V8 Vogue |
Well I chickened out and took my car to Lovells Land Rover today, all 4 lower arms replaced and the result ? still lnock, not as bad but knocking.
Have you checked the ARB links? |
Strangely that was my first thought, one side is new after doing my offside air suspension bag, the otherside isnt. I drove round for a while with one link missing and there was no knocking, when I fitted the link the knocking was very pronounced. Other symptoms, if I go round a corner left or right theres no knocking (I assume if it was the drop links thats because it's under tension.
Did they do the ball joint cassette John?
