Home > In Car Electronics (L322) > Newer infotainment modules? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
different i-bus bit rate... ... - .- -.
9th Aug 2019 10:10am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
Did you check for compatibility with the earlier (2007 MY) electronics ?
9th Aug 2019 10:12am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
This is what I have bought looking at wiggs diy thought it would be ok doubting now...
9th Aug 2019 11:49am |
Aha
9th Aug 2019 11:53am |
That part no looks very close to the one I used successfully - only the initial 8 & A are different.
9th Aug 2019 12:48pm |
thanks - but that leads to my question - how can the bluetooth work on the new and old systems? Current stable:
9th Aug 2019 12:53pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
I think some of the other units may rely on the screen as well as the unit themselves.
9th Aug 2019 4:41pm |
I'm wondering when the CANBus system changed - whether it must have been later.
9th Aug 2019 6:19pm |
Yea but that wouldn’t make sense to change half way through the later infotainment setup ... hmmm Current stable:
11th Aug 2019 7:21am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2538 |
The canbus changed on MY10 L322 and L320 RRS and the D4 was introduced at MY10 with the new canbus specs. If the VIN has the A or later year indicator preceding the 6-digit number then the vehicle has the new canbus. |
11th Aug 2019 7:29am |
Yea which is when they swapped to fomoco by right? So what I do t get is why that works and anything else wouldn’t or has it not been tested? Current stable:
11th Aug 2019 9:52pm |
