![]() | Home > In Car Electronics (L322) > Newer infotainment modules? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
different i-bus bit rate... ... - .- -.
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
Did you check for compatibility with the earlier (2007 MY) electronics ?
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
This is what I have bought looking at wiggs diy thought it would be ok doubting now...
Aha
That part no looks very close to the one I used successfully - only the initial 8 & A are different.
thanks - but that leads to my question - how can the bluetooth work on the new and old systems? Current stable:
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
I think some of the other units may rely on the screen as well as the unit themselves.
I'm wondering when the CANBus system changed - whether it must have been later.
Yea but that wouldn’t make sense to change half way through the later infotainment setup ... hmmm Current stable:
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
The canbus changed on MY10 L322 and L320 RRS and the D4 was introduced at MY10 with the new canbus specs. If the VIN has the A or later year indicator preceding the 6-digit number then the vehicle has the new canbus. |
Yea which is when they swapped to fomoco by right? So what I do t get is why that works and anything else wouldn’t or has it not been tested? Current stable:
