Home > Maintenance & Mods (L322) > SWOLLEN WHEEL NUTS?
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
SWOLLEN WHEEL NUTS?
So just having the inside of one of my rear wheels sorted as whoever painted them before me (professionally) must have not prepped one area that good as there was some bubbling / missing paint,
Anywyas....
My wheel brace doesnt fit the nuts properly??? Luckily i work in a tool hire shop and a 7/8 socket fitted when it should be 22mm, so im guessing the wheel nuts have swollen???
Interested to hear peoples thoughts and experinces on this and what to do tto overcome, luckily tis wasnt at the side of the road...
Are new wheel nuts expensive?
Also pain in the backside with the deployable steps lol..
On another note what is the wheel nut torque settings? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #524069 8th Aug 2019 9:21am
common problem Daz...loads on the forum re this...
wheel nut torque is 140nm or 103lbs.. ... - .- -.
Post #524073 8th Aug 2019 9:44am
dazza1983
Thanks buddy.. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #524076 8th Aug 2019 9:55am
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
As Stan said, common issue.
Replaced all of my non locking ones on my old L322 when I swapped the winters on (reminds me I must list them for sale). Virtually all of them were 'bulging'.
As for the steps, just leave a door on that side open (stops air suspension trying to level it too). Even easier if you have the sprinter jack with the new top (must check if it fits the l405).
Ian. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #524079 8th Aug 2019 10:20am
dazza1983
I used the jack that came with the rangy, would fit with the steps deplyed, is there one that will fit?
Also what does anyone think of these? or should i buy genuine??
https://www.ebay.co.uk/itm/RANGE-ROVER-L32...Sw4CFYpujQ Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #524082 8th Aug 2019 10:29am
ianmacd
I would only get proper nuts from a reputable supplier. They could be anything off of eBay.
These things hold on your wheels and trust me (as I had it happen to my nearside front at 70 in a disco2), you do not want a wheel coming off while driving. Current: RR L322 2010
Post #524083 8th Aug 2019 10:48am
dazza1983
i know im not going to pay land rovers £105 lol Big Cry Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #524087 8th Aug 2019 10:53am
ianmacd
Ask Dan what he can do. I just checked where I got mine from and I didn't pay much more than that price on eBay and got OEM ones. Current: RR L322 2010
Post #524090 8th Aug 2019 10:59am
dazza1983
Wheel nuts sorted courtesy of dan.
Do you think it’s ok to change one at a time without jacking up the car or removing the wheel??
Also I bloomin dropped my side step board as I went to put it back on. There a bit weird in that I had 3 lugs set in the recess on the brackets and one was not pushing down almost like it’s ever so slightly bent?
Anyway a couple of stone chip size marks any way I can smooth these out? Looks like it’s bare ally so possibly wet and dry?! Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #524110 8th Aug 2019 1:35pm
ianmacd
I would be tempted to replace them one at the time. Current: RR L322 2010
Post #524115 8th Aug 2019 2:13pm
DrRob
Dan - search on here for my bottle jack tips to replace the Censored scissor jack Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524146 8th Aug 2019 4:52pm
ianmacd
Or this one: https://www.fullfatrr.com/forum/topic14177.html Current: RR L322 2010
Post #524147 8th Aug 2019 4:54pm
DrRob
Replace all swollen nuts with new one ones and ditch the locking wheel nuts.Both will cause a load of hassle sometime....
Check these solid ones out www.wrington.co.uk Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524149 8th Aug 2019 4:55pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
https://www.fullfatrr.com/forum/topic49511.html
Thumbs Up Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #524154 8th Aug 2019 5:36pm
DrRob
Just been out and replaced another swollen nut Censored
Swapped out in under 2 mins and torqued up to 140Nm Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524157 8th Aug 2019 6:13pm
