Home > Maintenance & Mods (L322) > 3.6 TDV8 inlet manifold repair
kbald
Another close up
 Current 2007 TDV8 Vogue Buckingham Blue
Post #524965 15th Aug 2019 5:54pm
Andy
I’ve just sprayed soapy water all over it and no bubbles. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #524967 15th Aug 2019 5:58pm
kbald
Did you give it time to heat up so the plastic expands? Also a bit of revving helps. If that doesn't show anything you probably need a smoke test to nightlight when an air leak is coming from. Good luck Current 2007 TDV8 Vogue Buckingham Blue
Post #524969 15th Aug 2019 6:02pm
Andy
I’ve had a smoke test done but nothing came out of the manifold
I’ll get it warmed up and try it again 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #524970 15th Aug 2019 6:05pm
Andy
Just tried it hot
No bubbles anywhere. No soot on the plastic cover either.
Post #524974 15th Aug 2019 6:54pm
kbald
Looks like all that is fine. Mine had some smoke marks on the cover.
What code is it throwing up? Current 2007 TDV8 Vogue Buckingham Blue
Post #524975 15th Aug 2019 6:59pm
cass
So my jb weld is still holding up after 2 weeks and just short of a thousand miles. It certainly looks like it is only the drivers side that fails so if/when mine fails I’m just going to replace the one unless there is a spate of passenger side failures by the time I need to do it
Thanks for all the posts so far, these all help with the repair decisions
Post #525102 16th Aug 2019 10:40pm
kbald
So my qbond lasted a week or so but was leaking again. Chipped what I could and now used puraflex u40 which is the same as sikaflex apparently. Will see how that goes. Current 2007 TDV8 Vogue Buckingham Blue
Post #526015 24th Aug 2019 4:38pm
cass
Well my repair has failed today, 3 weeks and just shy of 1500 miles and I got the restricted performance bong along with the P023 code. Oddly it was on the exact same place on the same road as the first time, I pulled into the same lay-by to reset. I now expect to replace the manifold but will try Sikaflex first.
The conclusion so far is that the solid epoxy repairs don’t last very long, but do last long enough to part ex or fool Schofield and his kittens.
Anyone looking for a 3.6 needs to check this very carefully as I’m guessing that a replacement will cost well North of £1000 if you’re paying Someone to do it which is easily enough to temp someone to dump a faulty one.
Post #526097 25th Aug 2019 6:10pm
cass
Sikaflex repair failed yesterday so I've concluded that there isn't an easy fix for this, I'm sorting a new manifold this weekend.
Post #527038 4th Sep 2019 2:02pm
kbald
I've ordered a new one as well as I don't think the sikaflex is holding but will check again at the weekend. eBay have a 10% code today for using the android app so brought the pain down to under £300 for the new manifold. Current 2007 TDV8 Vogue Buckingham Blue
Post #527580 10th Sep 2019 5:20pm
cass
I reckon you’ve confirmed that this isn’t a long term fix.
The other thing that swayed me was the thought of wrecking a turbo as I’ve got a pet theory about the P023 code.
When I was researching this problem I saw lots of claims that P023 meant that the turbo was fubared but I suspect that it’s driving with a fault that causes P023 that wrecks the turbo.
I’ve no facts to support this but my theory is any pressure leak after the turbo could cause the turbo to overspeed then wreck itself?
Post #527614 10th Sep 2019 8:57pm
