Home > General (L405) > 3ltr Diesel vs 4.4 sdv8
Page 3 of 4 <1234>
Bill
Red Merle wrote:
If it's an "Approved" car from a LR dealer, bear in mind that the "Approved" warranty will be cut, from 2 years to 1, for any cars sold after the end of August 2019 Shocked
I’m sure that will help the second hand prices enormously !
On that note as we see the new prices steadily marching upwards to new peaks, why don’t the second hand prices follow...
Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #526484 29th Aug 2019 7:35pm
Ukandrewf
Perhaps because with all those gadgets there’s a lot more to go wrong on an older car out of warranty = more costs? --
On my third Full Fat RR
Post #526488 29th Aug 2019 7:57pm
DangerMouseUK
United Kingdom 2017 Range Rover Autobiography SDV8 Farallon Black
Do the new SDV6 models not have active suspension either?
I thought they did now.
Post #529447 29th Sep 2019 1:14am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I’ve been through the current brochures and spec. sheets and can’t find any reference to it in either car - which might even mean that neither now have it.
It reminded me that the SDV8 comes with the active rear diff though - which, if you use the off road screen, you can see it regularly switching between locked and open, even on road!
Post #529453 29th Sep 2019 8:55am
Red Merle
Maybe it’s because many buyers swap their used cars more often that once every two years and the dealer (and hence the buyer) are having to pay for two years, yet only using one. I’ve crazily done that three times in seven years!
Post #529454 29th Sep 2019 8:58am
GraemeS
Australia
LR will not have started fitting conventional shocks to the L405 in place of the CVDs as the ride and handling with CVDs is far superior to that of conventional shocks. L405s have always been fitted with CVDs which started as standard fitment with the MY11 L322.
Post #529457 29th Sep 2019 9:31am
Red Merle
What are CVD’s?
Post #529458 29th Sep 2019 10:04am
sounds serious, Wikipedia says this,
Cardiovascular disease (CVD) is a class of diseases that involve the heart or blood vessels ... - .- -.
Post #529460 29th Sep 2019 10:09am
Red Merle wrote:
What are CVD’s?
Continuously Variable Damper = Active suspension as it firms up when needed for cornering, but then eases off in a straight line to improve ride quality
On the warranty question - I thought Approved Used always used to be 1 year - it only changed to 2 years around 4 years ago - so they must have had a noticeable negative impact to revert again
Post #529461 29th Sep 2019 10:22am
Red Merle
Gosh, little wonder they don’t fit it! Wink
Post #529463 29th Sep 2019 11:02am
forever
So does my SDV6 Wink
Post #529472 29th Sep 2019 11:36am
Philip
The difference is the hydraulic anti-roll system which isn’t fitted to the V6.
Post #529477 29th Sep 2019 2:15pm
Red Merle
It’s just not a standard fit, which makes it a bit of a pain to find if you’re looking for a used one Sad
Post #529488 29th Sep 2019 4:16pm
forever
It was standard on the Hybrid model, probably why they cost so much Cool
Post #529520 29th Sep 2019 9:17pm
DangerMouseUK
Even on the newer SDV6 ones?
What is the LR speak for it as I can't seem to find it on the SDV8 or SDV6 L405s ?
The only difference between the two engines is the active diff on the SDV8
Post #529770 1st Oct 2019 11:44pm
Page 3 of 4 <1234>
