Home > Technical (L322) > Not Starting |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
I have had this twice? stopped the car after a drive ie: turned off the ignition, foot on the brake to start press button to start and the dash message is foot on the brake to start? as I already have my foot on the brake I can't understand why I get the message? I then shut down get out of the car lock the car wait for the computers to shut down and start again and it works after two times of pressing the foot on the brake as usual?
25th Jul 2019 11:26am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3780 |
The suggestion is only made as a temporary fix.
25th Jul 2019 12:49pm |
Hi, Mike on thinking about the starter I did hear a click from the starter which would point to that as the problem, could anyone point me where to source the parts to fix it myself? as I read your`s and others post.
25th Jul 2019 1:11pm |
It’s a couple of months since I searched for the best deal, but Opie Oils was the best deal with free delivery.
25th Jul 2019 1:20pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Just check all the connections first, including the earth straps. easier and cheaper....
25th Jul 2019 3:21pm |
Thanks, I will check them aswell |
25th Jul 2019 4:06pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 904 |
What engine is this tinman ? |
25th Jul 2019 4:43pm |
2011 4.4 v8tdi |
25th Jul 2019 4:51pm |
It will just be the contacts in the starter motor just order a rebuild kit easy fix |
25th Jul 2019 4:58pm |
Where do you order them from? |
25th Jul 2019 5:19pm |
I got mine off the bay of thieves loads of sellers on there doibg denso repair kits |
25th Jul 2019 6:47pm |
We have all failed to find a repair kit for the 4.4 tdV8 starter motor. solenoid contacts.
25th Jul 2019 8:36pm |
Ok i have messaged the guy i use who got me a kit for my m62 4.4 petrol most of the kits are very similar they even do a genral one that fits a dozen or so denso starters |
25th Jul 2019 11:03pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 902 |
TBH, by the time you've taken out the old starter to replace the contacts in the solenoid, you'd be better off (and more confident of a permanent fix) if you just replaced the whole starter.
26th Jul 2019 8:22am |
