Home > Technical (L322) > Not Starting
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Not Starting
I have had this twice? stopped the car after a drive ie: turned off the ignition, foot on the brake to start press button to start and the dash message is foot on the brake to start? as I already have my foot on the brake I can't understand why I get the message? I then shut down get out of the car lock the car wait for the computers to shut down and start again and it works after two times of pressing the foot on the brake as usual?
I was thinking it could be foot brake switch or something else?
It`s one of those intermitting faults any idea`s anyone?
Post #522730 25th Jul 2019 11:26am
rjff
Might sound like a wind up, Wink but try turning on, switching the wipers on and off then try starting the car. Not had this yet, but that is reported by Baltic Blue.
Try a search for similar faults as yours. There a some about with fixes and it can sometimes be useful to try a google search using fullfat in the search line as it is said the results can come up from here more relevant sometimes. Cheers
Richard
Gap IIDBT
Post #522740 25th Jul 2019 12:37pm
Baltic Blue
The suggestion is only made as a temporary fix.
The real long term fix is likely to be the starter motor.
https://www.fullfatrr.com/forum/topic51227.html
Post #522743 25th Jul 2019 12:49pm
Tinman
Hi, Mike on thinking about the starter I did hear a click from the starter which would point to that as the problem, could anyone point me where to source the parts to fix it myself? as I read your`s and others post.
Thanks all for your input Thumbs Up
Post #522744 25th Jul 2019 1:11pm
Baltic Blue
It’s a couple of months since I searched for the best deal, but Opie Oils was the best deal with free delivery.
Don’t forget to apply FULLFAT discount code.
Post #522747 25th Jul 2019 1:20pm
Just check all the connections first, including the earth straps. easier and cheaper....
Post #522759 25th Jul 2019 3:21pm
Tinman
Thanks, I will check them aswell
Post #522766 25th Jul 2019 4:06pm
Gsxr1250dave
What engine is this tinman ?
Post #522775 25th Jul 2019 4:43pm
Tinman
2011 4.4 v8tdi
Post #522776 25th Jul 2019 4:51pm
Gsxr1250dave
It will just be the contacts in the starter motor just order a rebuild kit easy fix
Post #522777 25th Jul 2019 4:58pm
Tinman
Where do you order them from?
Post #522779 25th Jul 2019 5:19pm
Gsxr1250dave
I got mine off the bay of thieves loads of sellers on there doibg denso repair kits
Post #522787 25th Jul 2019 6:47pm
Baltic Blue
We have all failed to find a repair kit for the 4.4 tdV8 starter motor. solenoid contacts.
Post #522803 25th Jul 2019 8:36pm
Gsxr1250dave
Ok i have messaged the guy i use who got me a kit for my m62 4.4 petrol most of the kits are very similar they even do a genral one that fits a dozen or so denso starters
Post #522813 25th Jul 2019 11:03pm
mpirie
TBH, by the time you've taken out the old starter to replace the contacts in the solenoid, you'd be better off (and more confident of a permanent fix) if you just replaced the whole starter.
I should add that the starters fail because of poor contacts in the solenoid, so unless the replacement kit is of OEM standard, you could find that there is little (or no) improvement.
Mike
Post #522824 26th Jul 2019 8:22am
