Home > Technical (L322) > Yaw sensor fault Hsbc air sus etc FIXED ******
Rewmer
I keep getting a recurring yaw sensor open circuit fault on my 2003 v8. It is intermittent but getting more regular. I’ve changed the sensor but still the same. IID reports that when it faults the air sus has a can fault also if it faults whilst driving it’s usually accompanied by the brakes momentarily applying which is rather disconcerting. I’ve checked connections at the abs unit. Any suggestions as to where to look next. I did find a post from years back with exactly the same problem, but the OP never reported back on whether it was fixed or not I have BT IID. No7 - 2003 V8 Vogue
Post #522484 22nd Jul 2019 3:58pm
stu1
We had one once that would randomly fail when warmed up leading to the usual DSC fail, suspension fail etc.
The solution was to keep the rear vents on cold with minimal rear fan so the centre tunnel is kept cool Very Happy
Post #522492 22nd Jul 2019 5:39pm
Rewmer
Changed the sensor out and it’s still exactly the same temperature doesn’t seem to play any part in faulting. No7 - 2003 V8 Vogue
Post #522494 22nd Jul 2019 6:21pm
Rewmer
The yaw sensor fault code was followed by 52 which relates to the suspension ecu. Tried swapping this out as well but still exactly the same. Does anyone have wiring details on the yaw sensor ? I can’t find it in Rave . No7 - 2003 V8 Vogue
Post #523241 29th Jul 2019 8:20pm
Rewmer
Well after a lot trouble shooting I tracked it down to the ABS ECU. I would seem those little hair like wires had broken on the yaw sensor connection. £200 later after repair at ECU testing and we are back on the road. No7 - 2003 V8 Vogue
Post #528363 17th Sep 2019 5:53pm
Lenb
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
How did you “track it down”?
I would be interested to know how you finally tracked it down to ecu. I’ve just posted my own problem asking if gearbox and/or alternator repair could have caused what seems similar problems to yours.
Lenb Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr
Post #533996 12th Nov 2019 9:10pm
Rewmer
Swapped out the ecu with a replacement - fault gone. Although it through up lots of other faults as it was not coded to the car, the yaw sensor fault was gone. No7 - 2003 V8 Vogue
Post #534027 13th Nov 2019 7:36am
