Home > Technical (L322) > Yaw sensor fault Hsbc air sus etc FIXED ****** |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
We had one once that would randomly fail when warmed up leading to the usual DSC fail, suspension fail etc.
22nd Jul 2019 5:39pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Changed the sensor out and it’s still exactly the same temperature doesn’t seem to play any part in faulting. No7 - 2003 V8 Vogue |
22nd Jul 2019 6:21pm |
The yaw sensor fault code was followed by 52 which relates to the suspension ecu. Tried swapping this out as well but still exactly the same. Does anyone have wiring details on the yaw sensor ? I can’t find it in Rave . No7 - 2003 V8 Vogue |
29th Jul 2019 8:20pm |
Well after a lot trouble shooting I tracked it down to the ABS ECU. I would seem those little hair like wires had broken on the yaw sensor connection. £200 later after repair at ECU testing and we are back on the road. No7 - 2003 V8 Vogue |
17th Sep 2019 5:53pm |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
I would be interested to know how you finally tracked it down to ecu. I’ve just posted my own problem asking if gearbox and/or alternator repair could have caused what seems similar problems to yours.
12th Nov 2019 9:10pm |
Swapped out the ecu with a replacement - fault gone. Although it through up lots of other faults as it was not coded to the car, the yaw sensor fault was gone. No7 - 2003 V8 Vogue |
13th Nov 2019 7:36am |
