Home > Maintenance & Mods (L405) > L405 sdv8 4.4l oil leak
Ielk2001
Hi all, so looking at buying a 2013 autobiography for what is a v good price. However it has oil evident from underneath the vehicle. Appreciating it's impossible to tell what might be causing, I'm hoping that someone may look at this and have had similar and can share what their cause was / cost to repair.
Post #521984 17th Jul 2019 7:08am
GGDR
The 4.4 can be a bit leaky.
There are a few possibles ranging from cheap to expensive.
Suggest you get it in somewhere for inspection, then get a quote and go back to seller with your size nines on and bid him allowing for possible cost of fix.
. Cheers, Greg
Post #521989 17th Jul 2019 7:42am
Ielk2001
Thanks. As I've already negotiated a very decent deal, my plan is to go ahead and hope for the best. But was curious if you had any ideas based upon experience?
Post #521990 17th Jul 2019 7:44am
Baltic Blue
https://www.fullfatrr.com/forum/topic35977-300.html
The 4.4tdv8 L322 is basically the same as an early L405 , engine wise. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #521991 17th Jul 2019 7:56am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I have an oil leak on my 4.4 SDV8 on the seal between the engine and gearbox (it wasn't there 3 weeks ago) . I have done 55k miles in the car which is 5.5yrs old and to replace the seal involves removing the gearbox and so the main dealer cheapest quote for me is £1,100 so going ahead as I don't want to risk any form of engine failure due to lack of oil as that would make this seal change cost insignificant. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #522199 19th Jul 2019 4:17pm
Ielk2001
Oh no sorry to hear that. I'm just confused a) why these cars are so popular and b) why, after all this time, land rover cannot make a reliable vehicle. That said, it isn't stopping me buying one...
Post #522216 19th Jul 2019 6:45pm
GraemeS
Is it certain that the oil is leaking from the rear seal rather than running down from the top at the back of the V from a leaking oil cooler?
Post #522222 19th Jul 2019 8:40pm
mjdronfield
https://www.fullfatrr.com/forum/topic35830.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #522224 19th Jul 2019 9:02pm
Vogue
It could simply be the oil filter and it’s seal that isn’t fitted correctly - located upside down on top of engine. I had this on a 12 month old L322 4.4 TDV8 which is essentially the same engine.
It made a mess and wasted my time getting it into another MD to be fixed, because an inept mechanic didn’t check or complete his work correctly. I billed them for my time and they paid - but did offer a free service as an alternative. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #522229 20th Jul 2019 2:13am
RRVSE
Interesting you should say that as there was no apparent leak when it was in 3 weeks ago - for an oil change!! I'll have them check the filter - thanks Steve
Post #522270 20th Jul 2019 12:18pm
Baltic Blue
I invested £5 buying a 36mm socket, because it is the best way to be sure the filter is refitted to the correct torque.
Post #522271 20th Jul 2019 12:32pm
Ielk2001
Just a quick update as according to the dealer who says it has been in to a specialist to have the oil leak investigated it is "slight misting from the turbo". I've been told (by the dealer) that it is fine for now and that in any case a failure to the turbo would be covered by the warranty. Any thoughts? Sound reasonable?
Post #522718 25th Jul 2019 8:25am
dingg1
Tell them to fix it.
Leaks get worse.
He's taking the Censored telling you it's nothing to worry about.
There's plenty other cars out there leak free.
Post #522719 25th Jul 2019 8:28am
CS
My 322 TDV8 (substantially the same engine and turbos) had a misting oil leak on one of the turbos. Dealer advice was that it was not bad enough to warrant intervention and that it should just be monitored. It was fine for the rest of the time I had the car and did not seem to get worse.
But "misting" is not going to cause visible oil at the bottom of the engine like your picture shows. So there may well be turbo misting on your car (I believe it is not uncommon, maybe associated with pre-turbo drain mod cars which would include 2013 MY?) but it should not be the cause of the leak you show. Suggest more investigation. Only Range Rovers since 1988
Post #522732 25th Jul 2019 11:51am
Ielk2001
Thanks all. Dealer has agreed, as condition of sale, to allow me to get oil leak investigated at my expense and for them to rectify at their expense. I think that's pretty reasonable so will get a RR specialist to investigate! Will let you know the outcome in case you come across it!
Post #522738 25th Jul 2019 12:33pm
