Home > Maintenance & Mods (L322) > Viscous fan removal?
Danwilderspin
Hi all on my 4.2 I’m trying to remove my viscous fan to make life easier changing my alternator.
Now on my m62 and every other car I’ve owned a 32mm spanner and a few smacks to the right loosen it off... now my 4.2 is a 36mm and I hit it about 20times with a sledge hammer and no dice... any ideas?
Also should the 4.2 have an electric fan as there appears wiring but looks blanked off from factory? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #521290 9th Jul 2019 10:42pm
rkaad
I had to do this on the 5.0 SC a few weeks back and in the end used a Coil Spring Compressor between the 2 spanners and wound them down.
Post #521304 10th Jul 2019 5:05am
gavinn
I always use a "heel bar" , pointed end on the nut and a good whack with a 4lb hammer , keep the bar as vertical as you can and 3/4 the way across the nut (to the right hand side when looking down at it standing in front of the vehicle), will give you a better turning moment of torque, normally shocks them off with no problem , remember its a left hand thread !
Post #521307 10th Jul 2019 6:40am
dingg1
4.2 is all dancing and singing electric controlled you will have a connector that goes into the rhs of the rad pack cowling as you stand in front of the car looking back.
Post #521313 10th Jul 2019 8:52am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I thought that it would be couple of taps & come undone when I did mine Shocked I even had the correct spanners, but ended up making my own to get more leveridge, Thumbs Up
Post #521341 10th Jul 2019 1:40pm
