Home > Maintenance & Mods (L322) > Viscous fan removal? |
rkaad Member Since: 10 Jan 2012 Location: London Posts: 12 |
I had to do this on the 5.0 SC a few weeks back and in the end used a Coil Spring Compressor between the 2 spanners and wound them down. |
10th Jul 2019 4:05am |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
I always use a "heel bar" , pointed end on the nut and a good whack with a 4lb hammer , keep the bar as vertical as you can and 3/4 the way across the nut (to the right hand side when looking down at it standing in front of the vehicle), will give you a better turning moment of torque, normally shocks them off with no problem , remember its a left hand thread ! |
10th Jul 2019 5:40am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
4.2 is all dancing and singing electric controlled you will have a connector that goes into the rhs of the rad pack cowling as you stand in front of the car looking back. |
10th Jul 2019 7:52am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I thought that it would be couple of taps & come undone when I did mine I even had the correct spanners, but ended up making my own to get more leveridge, |
10th Jul 2019 12:40pm |
