Home > Maintenance & Mods (L322) > car ramps |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Personally, I wouldn't use them. Others may have a different view. John
9th Jul 2019 5:47am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 516 |
I had a set of Machine Mart 2t (1t per side) start to buckle with my D3. I wouldn't risk it (and neither would I buy any car ramps from MM ever again!) 2016 Skoda Octavia VRS Estate
9th Jul 2019 7:53am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
These any good to you? I know they show unavailable presently, (were about £120 a pair ISTR)
9th Jul 2019 8:50am |
I've got a set of Rhino Ramps which are very good and much easier to lug around than metal ones. 2016 Skoda Octavia VRS Estate
9th Jul 2019 8:55am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Buy a couple of OAK sleepers and saw in half diagonally 2/3 - 1/3
9th Jul 2019 10:44am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
do them yourself for next to nothing
9th Jul 2019 1:40pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35259 |
i have those plastic ones that split in two..very robust and they wont rust ... - .- -.
9th Jul 2019 2:41pm |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Hi Stan,
9th Jul 2019 9:52pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
I'm not sure I want to use ramps that split in two! Be a bit careful with ramps. I used mine in the backyard on the grass and they were fine. A bit later, I wanted to degrease the engine so I put the ramps out in the front yard which is gravel (I'm a long time British car owner, all of which marked their territory). I got the RR halfway up the ramps when one slipped sideways nearly dropped it off the ramp. I didn't degrease the engine! Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
9th Jul 2019 11:10pm |
@littlecub, got these of ebay...
10th Jul 2019 7:09am |
Thanks Stan,
10th Jul 2019 8:52am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
I have a set of the plastic ones but one piece that look the same as stans. Work really well and are very sturdy. I slip a couple of axle stands under for good measure but it's a belt and braces job. Plus the plastic ones are lighter than the metal stuff and less noisy too! Current 2007 TDV8 Vogue Buckingham Blue |
10th Jul 2019 6:17pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
I’ve also got these but from Amazon. I saw Bodsy use something similar when getting the gearbox flushed at Dr Robs place. Steve. |
11th Jul 2019 12:42pm |
Thanks all for the tips on using the plastic jobby ones.
11th Jul 2019 8:14pm |
