Home > Maintenance & Mods (L322) > car ramps
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
car ramps
Am just wondering if 750kg per side car ramps would be suitable for our rangies?
This is only for using when I'm doing a service to my beast and nothing else.
Anything else (brakes etc) I normally get my local mechanic to do as I dont have the patience or tools to do properly.
TIA
Post #521146 9th Jul 2019 5:40am
Weegie
Personally, I wouldn't use them. Others may have a different view. John
GAP iiD BT
Post #521147 9th Jul 2019 5:47am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I had a set of Machine Mart 2t (1t per side) start to buckle with my D3. I wouldn't risk it (and neither would I buy any car ramps from MM ever again!) 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #521159 9th Jul 2019 7:53am
rjff
These any good to you? I know they show unavailable presently, (were about £120 a pair ISTR)
https://www.amazon.co.uk/SwitZer-Vehicle-H...B00X2BVB84
but they are about in singles
https://www.amazon.co.uk/dp/B01M6Z09QM/ref=dp_cerb_3 Cheers
Richard
Gap IIDBT
Post #521164 9th Jul 2019 8:50am
MikeO
I've got a set of Rhino Ramps which are very good and much easier to lug around than metal ones. 2016 Skoda Octavia VRS Estate
Post #521165 9th Jul 2019 8:55am
Buy a couple of OAK sleepers and saw in half diagonally 2/3 - 1/3
https://www.fullfatrr.com/forum/topic17310.html .
Post #521186 9th Jul 2019 10:44am
nino_nino
do them yourself for next to nothing Very Happy
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #521204 9th Jul 2019 1:40pm
i have those plastic ones that split in two..very robust and they wont rust Thumbs Up ... - .- -.
Post #521208 9th Jul 2019 2:41pm
littlecub
Hi Stan,
Can you give me more info about your ramps please.
TIA
Post #521292 9th Jul 2019 9:52pm
p38arover
Australia
I'm not sure I want to use ramps that split in two! Wink
Be a bit careful with ramps. I used mine in the backyard on the grass and they were fine.
A bit later, I wanted to degrease the engine so I put the ramps out in the front yard which is gravel (I'm a long time British car owner, all of which marked their territory). I got the RR halfway up the ramps when one slipped sideways nearly dropped it off the ramp. I didn't degrease the engine! Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #521300 9th Jul 2019 11:10pm
@littlecub, got these of ebay...
Post #521309 10th Jul 2019 7:09am
littlecub
Thanks Stan,
Was wondering if they be good enough for the RR. Thumbs Up
To p38a,
I'll take my chances in the back shed, but thanks for your concern.
cheers
Post #521324 10th Jul 2019 8:52am
kbald
I have a set of the plastic ones but one piece that look the same as stans. Work really well and are very sturdy. I slip a couple of axle stands under for good measure but it's a belt and braces job. Plus the plastic ones are lighter than the metal stuff and less noisy too! Current 2007 TDV8 Vogue Buckingham Blue
Post #521383 10th Jul 2019 6:17pm
gettingold
I’ve also got these but from Amazon. I saw Bodsy use something similar when getting the gearbox flushed at Dr Robs place.
Steve.
Post #521468 11th Jul 2019 12:42pm
littlecub
Thanks all for the tips on using the plastic jobby ones.
One of our auto places had 25% discount on so I bought the steel ones for less than the plastic ones delivered free. Thumbs Up
Have always had steel ones and altho the plastic ones are easy to move around,I prefer the steel ones.
cheers littlecub
Post #521516 11th Jul 2019 8:14pm
