Home > Technical (L322) > Danger - anyone else had a tow bar detach mid journey?
p38arover
Australia
Weegie wrote:
@P38. How do you get on with different trailer heights?
Generally, it's not a problem.
I have, in the past (with my P38A), removed the towball, turned the tongue upside down, and then refitted the towball. That gave a few inches difference. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #521150 9th Jul 2019 7:00am
Weegie
Thumbs Up John
GAP iiD BT
Post #521152 9th Jul 2019 7:11am
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
I have the Westfalia Flange Towbar which slots into the carrier and is secured by a large pin. I don't think it could detach provided the pin is secured correctly. There is however a tiny amount of play between the towbar and the carrier, which means that it cluncks rather alarmingly when towing on a bumpy road.
 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #521206 9th Jul 2019 1:58pm
TJH1985
kezbo1981 wrote:
TJH1985 wrote:
Farmers Hitch here Mr. Green it’s agricultural and can be noisy even with a perfect nose weight but it’s very secure, and when not fitted with the bung in the receiver the car looks great 👍
same here, I went for the farmers hitch because removed it looks less intrusive than the westfalia swan neck one. I got mine from pf jones also. my only concern is that some scroat could unpin the trailer very easily, so if I'm leaving the car and trailer I tend to padlock the two together.
I never considered that Shocked
Although I assume you can just as easily do the same with the swan neck receiver?
I tend to leave a hitch lock on when it’s unattended, so even if they did pull the pin they would still have the hassle of removing the hitch lock.. which would likely slow them down by 30 seconds if they were equipped. All these measures stop the opportunist at best in my mind.
Post #521212 9th Jul 2019 3:26pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
44,497 miles towing over 2 ton, no problems with the detachable.
For those with a farmers hitch LR do a bolt which replaces the pin and when torqued up stops all the rattling and clonking.
Ian
Post #521312 10th Jul 2019 7:34am
rw90
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Do you happen to know the part number?
Post #527249 6th Sep 2019 4:02pm
It reduces the rattling - but it still moves
There have been 3 versions over the years - and I've had all 3 -
smooth hole with pin
smooth hole with bolt
half threaded with bolt
You need the half threaded hitch to stop the rattling all together, but then it's not easy to remove - so you need to decide the trade off - I preferred the pin as I didn't't usually leave it on the car when not in use.
However, if removing it, there's no easy storage location - which is the story behind one of my 3 variants - having arrived in Bordeaux, I went to collect my boat & remembered that I'd left the hitch in my garage in England Embarassed Luckily the local dealer had one in stock.
Post #527251 6th Sep 2019 4:15pm
GraemeS
Australia
I welded a bolt onto the end and use a thick plate under the nut to clamp the shaft forwards which stops all rattling and also stops the pin from being removed.
Post #527276 6th Sep 2019 9:15pm
Nick591
Now that's a good idea!👏 Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #527278 6th Sep 2019 9:55pm
Andy
I use the farmers hitch and to stop the rattling I bought this bracket off eBay for £8.99 Works a treat.
 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527820 12th Sep 2019 4:34pm
AJGalaxy2012
How do these modifications sit with the towbar approvals in the event of something going wrong, would insurance still be valid?
I modified a towbar (welded an eye onto it for the break away cable) and it was commented on during a roadside inspection by VOSA. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #527823 12th Sep 2019 4:46pm
Andy
I’m trying to work it out mentally in my head what you’ve done there. Got a photo so I can understand it better? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #527825 12th Sep 2019 4:59pm
