![]() | Home > Technical (L322) > Danger - anyone else had a tow bar detach mid journey? |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1550 ![]() ![]() |
Generally, it's not a problem. I have, in the past (with my P38A), removed the towball, turned the tongue upside down, and then refitted the towball. That gave a few inches difference. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA Last edited by p38arover on 9th Jul 2019 12:02pm. Edited 1 time in total |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3250 ![]() ![]() ![]() |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I never considered that ![]() Although I assume you can just as easily do the same with the swan neck receiver? I tend to leave a hitch lock on when it’s unattended, so even if they did pull the pin they would still have the hassle of removing the hitch lock.. which would likely slow them down by 30 seconds if they were equipped. All these measures stop the opportunist at best in my mind. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
44,497 miles towing over 2 ton, no problems with the detachable.
rw90 Member Since: 07 Mar 2019 Location: Scotland Posts: 35 ![]() ![]() ![]() |
Do you happen to know the part number? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7978 ![]() ![]() ![]() |
It reduces the rattling - but it still moves
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2599 ![]() ![]() |
I welded a bolt onto the end and use a thick plate under the nut to clamp the shaft forwards which stops all rattling and also stops the pin from being removed. |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Now that's a good idea!👏 Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I use the farmers hitch and to stop the rattling I bought this bracket off eBay for £8.99 Works a treat.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
How do these modifications sit with the towbar approvals in the event of something going wrong, would insurance still be valid?
I’m trying to work it out mentally in my head what you’ve done there. Got a photo so I can understand it better? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
