Home > In Car Electronics (L405) > SIM card
Texritter
United Kingdom 2018 Range Rover Autobiography TDV6 Carpathian Grey
SIM card
Having a problem with fitting a sim card. I go thru settings, connections it then asks me to agree to terms/conditions then says immediately no connection. Does the same when i try to initiate wifi, No wifi available. Sounds like something is either not initiated or there's a broken connection to the antenna. Too busy to take back to the dealer at present.
Another weird one. How the hell do you fit the rear executive pillows? Its like a mensa test
Post #520926 7th Jul 2019 9:29am
Have you tried the SIM card in another device ?
Post #520927 7th Jul 2019 9:42am
Lyonhead
Wales 2019 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Just secure the one side of the headrest with the pillow cover and then pull across the front of the headrest and secure round the other side.
Thumbs Up 19MY SVA-Dynamic Spectral Chromoflair Blue but colour not available in profile
2016 RRS SVR Estoril Blue - Gone
2010 RRS 5.0 Supercharged Navara Bronze - Gone
2008 RRS 4.2 Supercharged Black - Gone
2006 RRS 2.7 Diesel Rimini Red- Gone
Post #520946 7th Jul 2019 12:04pm
Texritter
Thanks for the quick reply guys.
SIM is definitely ok. Enabling wifi should work SIM or not. Not sure if there's a hidden or service menu that enables comms. Looks like I'll have to make time to take it back although when I picked the car up they seemed to know less than me about the workings of it. Palmed me off with "I'll call in a couple of days to see if there's any problems" that was 3 weeks ago. Heard nothing since.
I'll give the pillows another go
Post #520961 7th Jul 2019 2:08pm
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
So similar issue for me, I've put in two Micro Sims and all the car does is say "reading SIM". It won't every connect to the SIM.
I've just had the software updated. I've managed to connect the WiFi to the House wifi but can't work out what to do to get the SIM to work. 1994 Range Rover LSE Autobiography
1994 Range Rover Vogue LSE Softdash
1994 Range Rover Vogue LSE (transmission failed so now a donor car!)
1994 Range Rover Vogue LSE (knackered donor car!)
1993 Range Rover Vogue LSE
1969 Aston Martin DB6 Vantage
1953 Lagonda DB3.0 Drophead Brooklands
1939 Lagonda LG6
Post #525740 21st Aug 2019 4:41pm
Ukandrewf
What does installing the sim actually do? Just allow in car WiFi? --
On my third Full Fat RR
Post #525930 23rd Aug 2019 1:21pm
I think it also allows the car to download data for the navigation etc.. 1994 Range Rover LSE Autobiography
1939 Lagonda LG6
Post #525934 23rd Aug 2019 3:02pm
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Yes - navigation data, traffic updates etc. 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #525947 23rd Aug 2019 5:28pm
Chalky
What year is your car Texritter?
My car had problems since the day I bought it (April 2018), with Wifi Connections. It was intermittent. Eventually they had to fit a new MCU and now everything is fine. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #525998 24th Aug 2019 10:25am
Chalky
Anyone know what this mesaage means? I put a new 12GB 3 simcard in two weeks ago. I wish the bloody photos would come out the right way up though Banging Head
Post #527576 10th Sep 2019 4:10pm
Brian Considine
Probably means you have actually used all the data up - auto-backup & similar will eat up data very quickly.
Make sure that you disable anything that uses data that you can do without. 2003 Range Rover Vogue TD6
Post #527584 10th Sep 2019 4:58pm
Chalky
Nothings changed from my first 3 simcard which was only 4Gb and lasted a year! Where can I change settings? It only appears when Apple Carplay is connected. All LR cars from 1984
Post #527586 10th Sep 2019 5:05pm
Fifth Horseman
Don't know why this would happen only with CarPlay active but then Landrover software does seem to be selectively stupid.
If on the vehicle display you go to All settings->Connectivity->Mobile Data and press Mobile settings yo then get a screen that enables a usage limit to be set/unset - its possible that the usage limit has somehow become enabled.
Post #527687 11th Sep 2019 1:26pm
Chalky
I think that's exactly it FH!!
I went on MY3 website last night and it said my usage was finished but that was with my original simcard. For some reason my new card hadn't been registered with them, although I did it and they knew about it.
All's well now and thanks to everyone for your input Thumbs Up All LR cars from 1984
Post #527689 11th Sep 2019 1:35pm
Triarii
Hijacking this thread a bit - I have a sim fitted and I understand its used for traffic updates etc - but today I was out and about (High Wycombe so hardly Timbuktoo) and on starting up the car and setting the nav for home the screen said there was no internet signal and something like 'limited navigation' and directed me to look at some menus. I'd have thought with no signal the car would revert to normal maps, not give up the ghost altogether and ask me to faff about? Or is this the usual LR over complication?
Within 2 minutes it went back to normal but this made me wonder what would happen if I really was somewhere with no signal. 17 MY Corris Grey 4.4 VAB
Post #527924 13th Sep 2019 4:20pm
