Home > Maintenance & Mods (L405) > Running a RR and saving money |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3823 |
I decided that the OEM JLR mats were lacking a bit so I bought BRITPART as recommended by Craig and palli as they cover more, particularly on the drivers side. I also thought what's the point of the recess in the boot if you have to fit the grossly overpriced OEM side net to make it useable, so I bought one from a chandlery for a few quid (I knew my days down a Cowes weren't wasted) I deliberately left the gap at the bottom so I can easily get the boot mat in and out. I used de-icer for the photo only - not much call for it in July rest of the stuff is the RSE headphones and a can of pop
5th Jul 2019 1:46pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
Looks good
5th Jul 2019 2:04pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
you've got a good memory Alistair...
5th Jul 2019 2:13pm |
@geoff , the mat looks good ..why dont they only do the fronts i wonder ...
5th Jul 2019 2:31pm |
....and you ended up with a set of 4..
5th Jul 2019 2:34pm |
Geoff has better locations due to a smaller net.
5th Jul 2019 2:36pm |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 201 |
Why didn't they just fit the same hooks each side as they did in the l322. Its like the sunglass holder (that's made it to the disco sport) that was dropped too and that's even more useful. Current: RR L322 2010
5th Jul 2019 2:53pm |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 353 |
Is it Cam Tech Craig whose used a Ford sunglass holder? |
5th Jul 2019 3:38pm |
yes it was..its .in his range rover thread... ... - .- -.
5th Jul 2019 3:48pm |
5th Jul 2019 3:50pm |
5th Jul 2019 4:02pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 602 |
have WD40 in mine would be lost with out it |
5th Jul 2019 6:45pm |
Actually the net slides up and down on the clips so I repositioned the top ones so now it reaches the bottom and I can raise it if I need to remove the rubber mat. Geoff |
7th Jul 2019 9:49pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Where can i buy that net Geoff?
10th Jul 2019 9:17pm |
