Home > In Car Electronics (L405) > Dash cam recommendation |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
Next base 412 from Halfords. Has a little battery inside it for parking mode so will record any vehicle movements. Bluetooth to an App to set it up. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Jun 2019 7:43pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
I would avoid anything with Nexbase on it.
25th Jun 2019 10:33pm |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 |
I’ve had a look at the reviews for the nexbase and they’re not good to be honest. Although it only seems the sensor thing when parked up is the issue. not Sure if I would even use that. |
26th Jun 2019 5:57am |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
I've got Nextbase 512 GW's in two vehicles and both have been trouble free. I initially had an issue with with card errors but it soon became clear I'd bought fake SD cards--theres alot about. Bought high quality replacements from a reputable source and all was fine. No hanging or other issues and just leave them to do their job. In the RR I have front and rear cameras. The rear camera shows as a picture in picture if required. Fitting a rear camera as well does reduce the quality, but it's still very good. Parking mode works fine, although as said, internal battery life isn't fantastic. |
26th Jun 2019 7:00am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
this one is highly recommended...wifi, capacitor and about £40-50 on ebay..
26th Jun 2019 7:16am |
To add to my comments the SD cards are all reputable makes bought from reputable sources. We have tried rotating the cards to no avail. The cards work fine in other devices so it cannot be the cards at fault. 2003 Range Rover Vogue TD6 |
26th Jun 2019 8:45am |
My original SD cards worked ok in other devices too, however there are different classes and speed of card. I replaced with U3 speed Nextbase cards and have had no issues since. |
26th Jun 2019 9:02am |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 905 |
Company called Dash Witness based in Faringdon but will fit products anywhere I believe, installed my front and rear Blackvue cameras. I also have the Power Magic pro hardwired in for parking mode. Very good kit and company, talk to Emmett or Eric.
26th Jun 2019 9:22am |
I appreciate what you are saying but all the cards in use are to Nextbase's spec's. The situation may just be tenable if Nextbase Customer Service knew what the word "service" actually meant. 2003 Range Rover Vogue TD6 |
26th Jun 2019 9:40am |
Perhaps buy one high end card and see how you get on. I believe the minimum requirement is Class 10, but ideally U3. What class are you using at present ? |
26th Jun 2019 9:51am |
Not too sure exactly what they are except that they are all to at least NB's spec's.
26th Jun 2019 10:31am |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 787 |
I’ve fitted a few of these to my cars and they work a treat. Buy a decent SD card though.
26th Jun 2019 8:15pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3184 |
@phil. That’s exactly what I’ve got - 70 mai. Can’t fault it. |
26th Jun 2019 9:47pm |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 231 |
I bought one of these -
27th Jul 2019 8:45am |
