Home > In Car Electronics (L405) > Dash cam recommendation
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
Just after a heads up on this. Don’t want to spend fortunes but need to sort one with all the idiots on the roads nowadays. Had an issue before last Xmas while in my van and if i’d Have had a dash cam it would of been a clean cut case in my favour.
Also I suppose I need to add. I haven’t a clue how they work. I’m guessing they record on a loop all the time they’re on?
Post #519645 25th Jun 2019 8:26pm
DrRob
Next base 412 from Halfords. Has a little battery inside it for parking mode so will record any vehicle movements. Bluetooth to an App to set it up. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #519648 25th Jun 2019 8:43pm
Brian Considine
I would avoid anything with Nexbase on it.
We have 4 various models in my immediate family & my next door neighbours have 2 - every single one keeps giving a variation of "no card error", "hangs" (not recording) and the battery duration abysmal.
When contacted at various time Nextbase were about as useful as an ashtray on a motorbike. 2003 Range Rover Vogue TD6
Post #519673 25th Jun 2019 11:33pm
Felstmiester
I’ve had a look at the reviews for the nexbase and they’re not good to be honest. Although it only seems the sensor thing when parked up is the issue. not Sure if I would even use that.
Post #519681 26th Jun 2019 6:57am
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I've got Nextbase 512 GW's in two vehicles and both have been trouble free. I initially had an issue with with card errors but it soon became clear I'd bought fake SD cards--theres alot about. Bought high quality replacements from a reputable source and all was fine. No hanging or other issues and just leave them to do their job. In the RR I have front and rear cameras. The rear camera shows as a picture in picture if required. Fitting a rear camera as well does reduce the quality, but it's still very good. Parking mode works fine, although as said, internal battery life isn't fantastic.
Post #519684 26th Jun 2019 8:00am
this one is highly recommended...wifi, capacitor and about £40-50 on ebay..
https://dashcamtalk.com/blueskysea-b1w/
Post #519685 26th Jun 2019 8:16am
Brian Considine
To add to my comments the SD cards are all reputable makes bought from reputable sources. We have tried rotating the cards to no avail. The cards work fine in other devices so it cannot be the cards at fault. 2003 Range Rover Vogue TD6
Post #519700 26th Jun 2019 9:45am
roberlar
My original SD cards worked ok in other devices too, however there are different classes and speed of card. I replaced with U3 speed Nextbase cards and have had no issues since.
Post #519705 26th Jun 2019 10:02am
Chalky
Company called Dash Witness based in Faringdon but will fit products anywhere I believe, installed my front and rear Blackvue cameras. I also have the Power Magic pro hardwired in for parking mode. Very good kit and company, talk to Emmett or Eric.
The cameras come with a 32Gb card but I would up that to 64Gb or larger. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #519706 26th Jun 2019 10:22am
Brian Considine
I appreciate what you are saying but all the cards in use are to Nextbase's spec's.
The situation may just be tenable if Nextbase Customer Service knew what the word "service" actually meant. 2003 Range Rover Vogue TD6
Post #519709 26th Jun 2019 10:40am
roberlar
Perhaps buy one high end card and see how you get on. I believe the minimum requirement is Class 10, but ideally U3. What class are you using at present ?
Post #519711 26th Jun 2019 10:51am
Brian Considine
Not too sure exactly what they are except that they are all to at least NB's spec's.
Just can't be bothered with them now. They will all be replaced at some point.
& to think that we all thought we were buying a premium product.
I appreciate your help - you have been far more helpful than NB themselves. 2003 Range Rover Vogue TD6
Post #519712 26th Jun 2019 11:31am
Phil.
I’ve fitted a few of these to my cars and they work a treat. Buy a decent SD card though.
https://www.amazon.co.uk/Minutes-Driving-R...B07D6LB6FS
As a comparison I have a top-end Blackview professionally fitted in my RR but don’t rate it above one of these, which I’ve recently fitted (front and back) to a new M5 Competition. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #519798 26th Jun 2019 9:15pm
Dolphinboy
@phil. That’s exactly what I’ve got - 70 mai. Can’t fault it.
Post #519807 26th Jun 2019 10:47pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
I bought one of these -
https://www.amazon.co.uk/Z-Edge-Recording-...amp;sr=8-4
The pictures are excellent, easy to set up, but... I've had 2 episodes at least where the camera failed to record, including some serious incidents which I had reported to the Police. I researched this and it appears to be a very common problem of SD card read/write failure, because dash cams are very hard on memory cards. The incessant read/write cycle can damage cards relatively quickly, so I took the plunge and bought a Transcend "Durable" card which is specifically aimed at dash cams. I only got it last week, so too early to report on any improvement, but it is certainly worth thinking about.
One convenience feature I would look for (which mine doesn't have) is wi-fi or BT download of video to your mobile, to save having to pull the SD card out of the camera and load onto a computer to view.
Post #522948 27th Jul 2019 9:45am
