Home > Technical (L405) > Restricted performance and Gearbox not in Park errors
Crasher242
Hello all
On my journey into work this morning i got "Restricted PErformance" warning on the display. After that it was extremely sluggish to pull way (although once up to about 50mph it then seemed okay).
Managed to continue my journey into work, although then when i parked up in the car park i got "Gearbox not in Park" error (and an annoying beeping) - when clearly i had put the car into Park before attempting to switch off.
Now mildly concerned that i may have issues getting home later.
Anyone experienced anything similar?
I suspect i might need to cal my local garage to get it booked in (although its not due a service yet).
I should add that the car behaved itself perfectly over the weekend... Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #518723 17th Jun 2019 8:53am
charlie croker mk2
When was the fuel filter last changed ? well worth doing if its been in place for 20 to 25 k Easy ish diy as well .
Post #518739 17th Jun 2019 11:25am
Crasher242
Good question - i've only had the car a few months and only done 5k in it.
I was thinking it could be "dirty" fuel though, as last fill was from a small village garage a couple of weeks back and i was running down to my last 90 miles or so on the run in this morning. Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Post #518743 17th Jun 2019 11:43am
charlie croker mk2
If that is 5K from new then it wont be the filter !
Post #518745 17th Jun 2019 11:52am
The OP's car is a 14MY Charlie...
Post #518748 17th Jun 2019 12:08pm
You really need to get the codes read sir...
Restricted Performance will leave a readable code and this should assist in diagnosing your issue Thumbs Up
Post #518749 17th Jun 2019 12:09pm
charlie croker mk2
Ahh 5k from new is unlikely then Laughing
Post #518750 17th Jun 2019 12:10pm
Crasher242
Ah I don't have a tool - although I know someone local who does....
Thanks Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Post #518751 17th Jun 2019 12:11pm
Crasher242
5k from when I got it (it had just under 82k on it). Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Post #518752 17th Jun 2019 12:12pm
charlie croker mk2
Good way to test for fuel filter problems is to find a deserted "up hill"race track and cause the car to need maximum fuel delivery IE go flat out for as long as you can or dare . If the filter is getting clogged this will cause the restricted performance warning to crop up .
Post #518828 17th Jun 2019 8:26pm
