![]() | Home > Technical (L322) > Starting issue |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
whirring sound ?
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 ![]() ![]() ![]() |
Have my doubts about it being the ignition barrel as it works I thought it could be the starter motor but the fact it always works second attempt makes me suspicious |
Still could be either (or both |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1392 ![]() ![]() ![]() |
The symptom of pressing the button and nothing happening, or just a click, and then at another attempt the car starts fine is consistent with a failing starter motor. That happened with my 2012 WM, and there are threads on here about it. I don't have any experience of the TD6 though, so it might be more a thing for later cars. Only Range Rovers since 1988 |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
my TD6 had a failing starter motor over a long period of time. Sometimes would spin over fine, other times a bit more slowly. sometimes it would even spin fast and then slower then day only a click and it was no more.
