Home > Technical (L322) > Starting issue
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Starting issue
Hi all,
I have a strange issue. I have no bongs other than an occasional HDC inactive and a low screen wash. The problem is that the car only starts on the second of third attempt.
I get a whirring sound but no ignition when I start it. Then turn it off and try again and the car starts. I have had alternator replaced last year so the battery should be ok. The car isn't getting driven very frequently during the week but at the weekend it gets usually gets a decent run.
Any suggestions on whats going on with the starting?
Car is a 2002 td6
Post #517218 2nd Jun 2019 12:11pm
whirring sound ?
Like starter motor going round ? Maybe the motor is not engaging ?
May be worth whipping it out and giving it a good going over with cleaning and lubricant, bench test etc.
If not a motor whirring sound, could be your ignition switch is on the way out, full of crud, try some easing fluid down the keyhole ? .
Post #517221 2nd Jun 2019 12:21pm
Teaspoonasaurous
Have my doubts about it being the ignition barrel as it works I thought it could be the starter motor but the fact it always works second attempt makes me suspicious
Post #517223 2nd Jun 2019 12:46pm
Still could be either (or both Twisted Evil ) .
Post #517225 2nd Jun 2019 1:06pm
CS
The symptom of pressing the button and nothing happening, or just a click, and then at another attempt the car starts fine is consistent with a failing starter motor. That happened with my 2012 WM, and there are threads on here about it. I don't have any experience of the TD6 though, so it might be more a thing for later cars. Only Range Rovers since 1988
Post #517268 2nd Jun 2019 6:30pm
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
my TD6 had a failing starter motor over a long period of time. Sometimes would spin over fine, other times a bit more slowly. sometimes it would even spin fast and then slower then day only a click and it was no more.
i would suggest you are in the same boat.
Post #517316 3rd Jun 2019 11:04am
