![]() | Home > Maintenance & Mods (L322) > Yet again suspension |
Check your front height sensors, either broken or reversed, or you exposed a hole in one of your airbags.... .
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
Reversing the height sensors is easily done after having the car fully jacked up. then the car doesnt kow whats going on a deactivate the suspension. |
mudknight Member Since: 21 Sep 2012 Location: birmingham Posts: 73 ![]() ![]() |
I've now checked the height sensors , they seem correct , I've disconnected the battery for an hour and half to see if things reset but they haven't , obviously fuses and relay checked . |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Height sensor wiring issue on that side?. Is the pump working, can you hear any air escaping?.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 986 ![]() ![]() |
Where about are you if your local il come plug my hawkeye in for you |
yelnats69 Member Since: 21 Dec 2019 Location: Dymchurch Posts: 35 ![]() ![]() ![]() |
Did you fix the problems |
Still having problems with the suspension , I'm looking into a cheap fault reader so I can just clear it as that's all they do every time I take it into mechanics |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
I guess that you have tried the full left lock to right lock engine on dance, whilst whistling The Good Bad and Ugly?
Where are you located I am in Dymchurch Kent will be in Portsmouth this weekend I can plug mine in and read and switch off the code |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Any money it’s the steering angle sensor at your age and mileage - you can change it fairly easily if you have small to medium hands Current stable:
for just reading and switching off codes, eBay bt reader under £10 and download Torque for free, codes are listed on the net. no help with the suspension though. Im trying to find what OBD tool will check and set the suspension |
will the sensor show up in fault codes, my problem just throws up the yellow suspension fault now and again |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
not sure anything cheap will do it, the only one I have seen is £50 quid on ebay and takes 60 seconds to clear EAS faults https://www.fobfix.com/products/range-rove...&_ss=r £50 quid on ebay https://www.ebay.co.uk/itm/Range-Rover-L32...SwclBbczzk |
