Home > General > did you know, well you probably did.
on the touch screen ranges, if you press and hold down the left stalk button for about 3/4 secs, a selection screen shows on the radio/nav and you can select what options you would like to be scrolled through on the dash lcd readout.. ... - .- -.
Post #55060 16th Mar 2011 4:24pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
If you have the 2010 onwards then the speedo moves to the right and you get a menu there................... same when you select any of the TR functions the speedo slides to the right enough to hide the section from 70-150mph as LR reckon you will never need that half of the speedo off-road Mr. Green 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #55062 16th Mar 2011 4:26pm
T24RES
You bored Scarey, been pressing all the buttons again?....................................plip plip Laughing Ian
Post #55063 16th Mar 2011 4:31pm
Embarassed yep................................but did you know? ... - .- -.
Post #55064 16th Mar 2011 4:32pm
wardpg
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Yep i knew---Got rid of both MPG readouts cos it depresses me too much Sad Sad Sad Ex D1, D2, D3 owner now 2008 TDV8 Vogue SE
Post #55068 16th Mar 2011 4:52pm
T24RES
I did, same as the bimmer i had............................. Thumbs Up Ian
Post #55105 16th Mar 2011 9:05pm
