![]() | Home > Maintenance & Mods (L405) > SDV8 MY14 oil smoke |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
The oil filter sits on the top of your engine towards the back of the engine or near your firewall bulkhead it sits under the black plastic engine cover . The filter sits inside a filter housing. If you just had your car serviced they probably spilt some oil down the back of your engine. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
The oil filter housing sits on the engine oil cooler and these leak for a past time! There is also an oil pipe fitted to the rear of the cooler which has two oil seals that fail often... Both of these can be found here by searching sir...👍
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7981 ![]() ![]() ![]() |
Useful thread - https://www.fullfatrr.com/forum/topic49251.html
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3793 ![]() ![]() ![]() |
This picture of a new engine shows the oil filter and cooler clearly, plus the green arrow I have added points to the connection where the leaking O rings pipe fits.
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
