Home > Technical (L322) > DIY wiring right side front
MariusRR
Norway 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Hi,
My Range Rover TDV8 L322 has some HDC issues. Diagnostics points to broken wire under right hand side front seat (LHD car).
Has anybody and guides etc for opening up and looking for wire problems between the Terrain response module and det right foot well?
VIN: SALLMAM247A249364
L322 - Range Rover 2007
Vehicle scanned on 21-05-2019 12:05
Using IIDTool BT V3.0 B2643
ATCM-Terrain Response
U0401-94 (2E) Invalid data received from engine control module/powertrain control module - Component failure - unexpected operation
( on 21-05-2019 12:04:35 at km )
U0402-94 (2E) Invalid data received from transmission control module - Component failure - unexpected operation
U0416-94 (2F) Invalid data received from vehicle dynamics control module - Component failure - unexpected operation
( on 21-05-2019 12:04:34 at km )
U0403-94 (2E) Invalid data received from transfer case control module - Component failure - unexpected operation
U0421-94 (2F) Invalid data received from ride level control module - Component failure - unexpected operation
HVAC-Heat / Cool
0x30 Air quality sensor line fault
TCCM-Transfer Case
U0122-87 (2F) Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message
( on 21-05-2019 12:04:46 at 227619 km )
TMC-Traffic Message
B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
Post #516080 21st May 2019 1:03pm
Hmmm....looks more like a battery / low voltage issue.
How is your battery and charging system ? (before you start dismantling and do any damage...) .
Post #516082 21st May 2019 2:16pm
MariusRR
Would normally agree, but the battery was new in february. I charged last night, still HDC not working, and DSC and yellow brake light lit. Not ABS. Also says Suspension lowering everytime I Start it ut.
Post #516087 21st May 2019 3:31pm
Did this issue arise in February , i.e. why you changed the battery ?
Have you cleared codes since then ? .
Post #516088 21st May 2019 3:54pm
MariusRR
These codes are aftter I cleared the codes.
Havent had any issues with the car until saturday, when I was driving in heavy rain. Been amber lighting ever since.
Post #516089 21st May 2019 3:56pm
ultron
Germany 2008 Range Rover Vogue TDV8 Java Black
Hi MariusRR,
did you find your fault?
I have a similar problem ....
L322 - Range Rover 2008
Vehicle scanned on 09-05-2021 19:48
Using IIDTool BT V3.0 B2742
( on 09-05-2021 19:44:58 at 144458 km )
( on 09-05-2021 19:45:00 at 144458 km )
U0416-94 (2E) Invalid data received from vehicle dynamics control module - Component failure - unexpected operation
FBH-Fuel Burn.Heater
0x0304 Circulation pump - Open circuit or short circuit to battery
HVAC-Heat / Cool
0x41 Park heater message disturbance fault
IPC-Instrument Pack
U2016-41 (2Cool Control module main software - System internal failure - general checksum failure
( on 08-05-2021 11:02:58 at 144399 km )
U0248-87 (2F) Lost communication with remote driver utility module - Bus signal/message failure - missing a message
TMC-Traffic Message
Battery is new and full....
thx sebastian
Post #593727 9th May 2021 7:45pm
MariusRR
Yes. Wire breakage to the yaw rate sensor.
Tried a lot of stuff first, like changing the yaw rate sensor, hdc ECU etc.
But it was a breakage.
Post #593728 9th May 2021 7:51pm
ultron
yaw rate sensor?? Where can I find that?
many thx
Post #593730 9th May 2021 7:54pm
MariusRR
I think it is buried somewhere in the mid console.
I am not that competent on fail searching electrics. But took my mechanic 1 hour to find the wire breakage. Suggest you do the same?
Post #593731 9th May 2021 8:03pm
