![]() | Home > Technical (L322) > DIY wiring right side front |
Hmmm....looks more like a battery / low voltage issue.
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 98 ![]() ![]() ![]() |
Would normally agree, but the battery was new in february. I charged last night, still HDC not working, and DSC and yellow brake light lit. Not ABS. Also says Suspension lowering everytime I Start it ut. |
Did this issue arise in February , i.e. why you changed the battery ?
These codes are aftter I cleared the codes.
ultron Member Since: 13 Nov 2018 Location: Hamburg Posts: 23 ![]() ![]() ![]() |
Hi MariusRR,
Yes. Wire breakage to the yaw rate sensor.
yaw rate sensor?? Where can I find that?
I think it is buried somewhere in the mid console.
