Home > Technical (L322) > Rear Shock Absorbers/Dampers
Blackbird51
Hi all
Soon going to undertake replacing the rear shocks/dampers. On workshop manual it states that the paper gasket between shock and body must be replaced. Can someone advise the part number for the replacement paper gasket or shall I just make new ones with greased card.
Post #515955 20th May 2019 3:15pm
Pawl
I just used thick paper & sprayed it with lacquer to give it some extra waterproofing.
They're not that critical. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #515990 20th May 2019 8:04pm
Blackbird51
Ok. Thanks
Post #516026 20th May 2019 11:48pm
ur20v
A Trap
You can get proper gasket paper from Halfords or other motor factors.
Post #516051 21st May 2019 7:45am
