Home > Maintenance & Mods (L322) > 2003 TD6 with 115k miles - what should i plan for |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
As you have already done the gearbox, you have done the most expensive bit. If you haven't already done the front suspension parts like shocks, control arms and ball joints, they should probably be on your list.
7th Apr 2019 7:50am |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
I am in a similar place with an 05 on 108k, Gearbox is done, front Air shocks.
7th Apr 2019 9:57pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
For an 03:
7th Apr 2019 10:53pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
My TD6 is at 150000 miles 245000klms. Fortunately, rust is non-existent here in West Australia but I have had to address a few things in my 4-year ownership from 195000klm. The in-tank Fuel pump packed up so I changed both, two injectors have given problems and have been changed both front struts and bags changed. Expansion tank float, All easy DIY with help from the forum once diagnosed. 2007 TDV8 VSE
9th Apr 2019 4:35am |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 |
mines touching 190k miles.
9th Apr 2019 2:18pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Hey Cooper I didnt do the calipers, i should of said just Brembo discs and pads all round. Fuel filter is done every 18 months and i changed the oil breather filter for the newer 'vortex' type. what/where is the inline filter for the turbo vent filter?? Im thinking of undersealing her this summer, was going to do it myself the old fashioned way though, scrape everything thats loose off with a wire brush, and waxoyl or hammerite everytihng i can see, unless theres a better way? |
3rd May 2019 7:20pm |
