Home > Maintenance & Mods (L405) > Full size spare wheel lift kit
Crasher242
Hello
I was sorting out my boot yesterday and noticed that i do not have a wheel lift kit - i have a full sized spare (20" wheels) and can see the jack located at the rear of the wheel well, but no lifting kit. I also dont have a prop for the wheel well cover.
I thought these things were standard (well standard if you opted for the full-sized spare) - and the original build list for my car had the full sized spare.
Anyone know if these things are available as an "add-on"?
I'm fairly tall and have a good upper body strength, but i have struggled to try lifting the wheel out unaided. They are mighty things! Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #510993 5th Apr 2019 12:20pm
Weegie
They are available as an add on. There are pre-drilled and tapped holes to accept them. Dan at Duckworths can supply. John
GAP iiD BT
Post #510994 5th Apr 2019 12:24pm
Lift kit is available - Dan@Duckworths supplied mine.
I think they only come as standard with 22’s
https://www.fullfatrr.com/forum/topic31758.html
Post #510995 5th Apr 2019 12:25pm
Chalky
Hi Crasher....sent you a pm. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #511025 5th Apr 2019 3:14pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
I found a brand new one on Ebay for about £25, the part number I believe is LR085460 and the retail is about £72 Shocked Cheers Ian
Kielder 4x4 Safari
Post #511132 6th Apr 2019 12:13pm
Crasher242
Thanks all for the replies (and PM's) Thumbs Up Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Post #511258 7th Apr 2019 7:02pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
£25 from Guy Salmon Sheffield - https://www.ebay.co.uk/itm/New-Spare-Wheel...Sw6idcp2Ef
Post #511280 7th Apr 2019 10:09pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Make your own as its not a dangerous item to injure with a few bolts and washers and a handle of timber https://www.ebay.co.uk/itm/50mm-Webbing-Ta...0005.m1851 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #511289 8th Apr 2019 1:22am
nino_nino
if you fancy some DIY this is the strap I made for my RR
https://www.fullfatrr.com/forum/topic42071.html
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #511295 8th Apr 2019 7:12am
The L405 has a different system - it’s kind of a hoist that attaches to the upper roof
Post #511299 8th Apr 2019 7:58am
nino_nino
Embarassed Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #511308 8th Apr 2019 8:36am
I think it’s because of the powered tailgate in the L405, because the L322 system seems much better IMHO
Post #511323 8th Apr 2019 9:44am
kiwirich
Australia 2017 Range Rover Vogue TDV6 Fuji White
The new version is effectively a pulley set using rings and webbing tape.
Hooks on the top of the boot opening.
Works well.
Kiwirich
Post #511634 11th Apr 2019 5:06am
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
Is there any reason that the l405 kit wouldn’t work on a l322? Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #511636 11th Apr 2019 5:37am
kiwirich
I haven't checked a L322, but basically the hook hoes in the top of the boot opening.
The other end goes into the wheel, then just pull on the webbing.
Sounds complex but actually All quite simple.
You do have to remove the boot base though.
I struggled to remove the wheel from the boot.
It is reasonably heavy but very awkward.
My wife simply couldn't do it.
Kiwirich
Post #511643 11th Apr 2019 6:56am
