![]() | Home > Maintenance & Mods (L405) > Full size spare wheel lift kit |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
They are available as an add on. There are pre-drilled and tapped holes to accept them. Dan at Duckworths can supply. John
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
Lift kit is available - Dan@Duckworths supplied mine.
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 912 ![]() ![]() |
Hi Crasher....sent you a pm. All LR cars from 1984
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
I found a brand new one on Ebay for about £25, the part number I believe is LR085460 and the retail is about £72 |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 136 ![]() ![]() ![]() |
Thanks all for the replies (and PM's) |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
£25 from Guy Salmon Sheffield - https://www.ebay.co.uk/itm/New-Spare-Wheel...Sw6idcp2Ef |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Make your own as its not a dangerous item to injure with a few bolts and washers and a handle of timber https://www.ebay.co.uk/itm/50mm-Webbing-Ta...0005.m1851 _____________________________________________________
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
if you fancy some DIY this is the strap I made for my RR
The L405 has a different system - it’s kind of a hoist that attaches to the upper roof |
I think it’s because of the powered tailgate in the L405, because the L322 system seems much better IMHO |
kiwirich Member Since: 19 Nov 2011 Location: Toowoomba Posts: 6 ![]() ![]() ![]() |
The new version is effectively a pulley set using rings and webbing tape.
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
Is there any reason that the l405 kit wouldn’t work on a l322? Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
I haven't checked a L322, but basically the hook hoes in the top of the boot opening.
